Others much more qualified than I will reply, but I would guess yes.
I would never run my Z on any gas below the best available option (which is 94, ethanol free here).
Yes on paper 93 will prevent knock than 91, but if you're getting KR on 91 then something may be wrong. The stock tune is pretty safe too though.
Yes; stock, tuned, modded all matters. I had mine tuned for 93 octane (use 94). The OP's car is stock and knocking on 91 octane... maybe needs to look into a tune?
No--i cant hear any knock--i just want the car to stay in the high octane table--so will be mixing 91 with unlead sunoco 100 to about 93-94 octane--also have a vararam so inlet temps should be good-live in vegas HOT summers
I understand, I'm in AZ. We don't bother with mixing and if you're stock you don't need to worry about it. Yes you may have KR if you're racing in the middle of summer because your IAT sensor will be conservative but I doubt you'll get KR due to actual knock.
Basic performance 101: increase airflow to increase power
Since you have increased how much air the engine can inhale the PCM must add some fuel to get back to the commanded AFR. Even though the computer can compensate, it is far from perfect and thus tuning is the best way to get the best performance with any change in airflow.
Even a mail order tune will get those LTFTs back down closer to 0. Far cheaper in the long run than always running 93+.
What I believe is happening is the added airflow has required additional fuel which the computer isn't able to get just right and you are sometimes a bit lean and even with stock timing it is causing a KR to occur. Lean KR can be troublesome because it can heat up the chamber and cause additional KR... turning into a constant power robbing situation.
Plenty of times you can have KR without hearing it - data logging will be needed to know for sure if the computer detects it.
You should be fine in a stock car. Unless its been tampered with, your car doesn't reach commanded factory PE until 5500rpm anyway. With 95deg heat your IATs overtime will pull timing. In a stock car 93 or 91 is wont run much different, if it all.
Mine got knock on 93. Changed the front knock sensor. Still got pinging and knock.
Took the heads off. Plenty of carbon. True knock. Removed the carbon, no more knock.
Higher octane gas wouldn't have been the solution. If you're getting knock (hence the computer pulling timing and throwing a knock code) you have issues other than 91 octane.
If you're in hot climate, consider spending for a 160* thermostat. Will help when rolling down the road, will still get hot (fans won't turn on sooner without tuning) below 35mph. Better than factory 195*
