Headlight goes down and back up on passenger side
Old May 18, 2017 | 06:57 PM
maxtower80's Avatar
maxtower80
3rd Gear
Default Headlight goes down and back up on passenger side
I read a lot about this problem trying to get mine fixed. What I found was the wires on the passenger side Headlight was getting cought in the crank arm by the Headlight motor and causing a bind.it would make the light think it was cycling and come back up. I checked the wires and roughted them through the inner body hole and plugged Evey thing back in and it works perfectly now.it didn't cost anything to fix,and I think it corrected a ground problem. I hope this will help someone out.
Old Jun 15, 2017 | 06:37 PM
vfmiller's Avatar
vfmiller
2nd Gear
I replaced my driver side headlight motor gear and now one light goes up and one goes down. Can't figure it out. any help would be appreciated.
Old Jun 15, 2017 | 09:41 PM
flyingjoey's Avatar
flyingjoey
I had that problem as well the actuator arm middle nut was not screwed all the way. Then I had the problem 1 would go down other up.. reversed the direction the arm travels to the notch stop. Fixed it
To Headlight goes down and back up on passenger side
