Mid pipe help
Old May 19, 2017 | 01:27 PM
Vettorious84's Avatar
Vettorious84
Default Mid pipe help
Afternoon fellas,
Will this Billy Boat mid pipe be a direct fit with the current system or will I have to cut and weld it on? Thanks in advance.
Old May 19, 2017 | 02:00 PM
RVETTE42's Avatar
RVETTE42
You will have to measure and cut off your original H pipe and slide on your new X pipe with clamps.
Old May 19, 2017 | 04:15 PM
Roddy13's Avatar
Roddy13
You already have an X-pipe up stream with the mid-pipe that is connecting to your headers.
What are you trying to achieve? Not much point in adding a second x-pipe.
Old May 19, 2017 | 04:20 PM
Vettorious84
The Billy Boat bullet isn't taking to that mid pipe too well so I want get put the BB mid on instead. I guess I'll have to cut and weld then.
Old May 19, 2017 | 04:21 PM
Vettorious84
If I cut after the cats wouldn't it be too short?
Old May 20, 2017 | 11:53 AM
RVETTE42's Avatar
RVETTE42
Do you have headers on your car now or is it stock? If those are your actual pics it looks like it's not stock so no need to cut off your original H-pipe.
Old May 20, 2017 | 02:15 PM
zeevette's Avatar
zeevette
What do you mean by "not taking it too well" on the X-pipe already installed?
To Mid pipe help
