Warning High Pressure
Old May 19, 2017 | 02:00 PM
Clancy209's Avatar
Clancy209
Default Warning High Pressure
Hour ride 90 degrees F. Rear tires went to 42psi and showed high tire pressure warning had to pull over and bleed a few psi from each tire. Never saw this before. Michelin run flats AS3
Old May 19, 2017 | 02:45 PM
C5Txfan's Avatar
C5Txfan
Add any air recently ? I had same issues several years ago with my GY RF's. I'd added some air using a digital gauge to check and a few days got the high pressure warning. Checked with trusty old style slide bar gauge and found they were high, the digital gauge was FUBAR big time. Chucked the digital and only use the 'old style' now - no more problems !
Old May 19, 2017 | 02:54 PM
FX VETTE's Avatar
FX VETTE
When I had a major brand tire store put new tires on my 03' the same thing happened as I left their lot after the install. Guess I should have looked while it was still parked there, but it turns out that the tech was reading the suggested PSI on my tires themselves instead of following the recommendation on the inside of my door and decided 42 PSI was a good number. My DIC freaked out I came back and schooled them about the 30 PSI Cold printed on the inside of the driver side door, but am not confident that they actually cared.
I have mine set at 30 PSI Cold, but notice that they typically jump up as high as 36 PSI when I'm driving around.
Old May 19, 2017 | 03:13 PM
ArtClassShank's Avatar
ArtClassShank
Hotter temps + hot tires will raise your PSI by a good amount. 10PSI increase not unheard of. 1 PSI per 10 degrees F is the general rule of thumb. Add more for the tire heating up as you roll down the road, it's not negligible!
Old May 19, 2017 | 04:21 PM
knewblewkorvette's Avatar
knewblewkorvette
Originally Posted by 8VETTE7
Tires must have been inflated well past the 30PSI information on the door placard before you started your drive. Per the owners manual the warning you received would be expected at 42PSI. Most tires will pick up 4 to 6 lbs when hot. So likely the tires started over 36PSI cold......
using the 1 psi to 10 degree rule, you tires would have gone up 120 degrees to achieve the 42 psi reading if they were at the correct pressure of 30 psi.
Old May 19, 2017 | 07:41 PM
MSUGTO's Avatar
MSUGTO
When my TPMS sensors were going out I would occasionally get a high air pressure warning on the DIC FYI.
Old May 19, 2017 | 08:14 PM
UM Rebel's Avatar
UM Rebel
PSI in Michelin ZP's reacts quickly to temperature change. I think it[s because ZP have smaller air cavity.
Old May 19, 2017 | 09:18 PM
You had to have way too much air pressure in the tires to begin with.
To Warning High Pressure
