Rodents in garage
Old May 20, 2017 | 07:40 PM
acuevo's Avatar
acuevo
Default Rodents in garage
So my wife and I bought our house just this past February. It was empty for several months before we moved in, there was a small mouse problem inside the house that we seem to have taken care of completely.
The garage, where the Vette lives, is a different story.
From what I can tell the droppings I'm finding are that of a roof rat. The worst part, theres none on the floor, on any of my boxes, on the tool bench... the little bastard seems to like shitting exclusively on my car. There will be blood.
Exterminator is coming for the quarterly visit this coming Thursday. I'm going to chat with him and see what he thinks, but I'd also like to hear from all of you, maybe someone has had a similar problem? Traps, bait, weird home remedies, flame throwers, machine guns, whatever, as long as it gets rid of them I don't care. I know these guys can be tricky, just looking for your experiences to see whats worked and what hasn't.
In addition there are several things I know need attention. The garage is hardly Fort Knox and there are a lot of places I need to seal up or stick steel wool in to keep any more from getting in. Also hopefully soon I can get my wife to go through all her stuff thats out there so there will be less clutter for them to hide in.
Thanks so much in advance!
Old May 20, 2017 | 07:49 PM
FX VETTE's Avatar
FX VETTE
that made me laugh - you're comment, not the fact that the mouse is crapping on you're Vette.
You seem to have a good plan and I've seen similar posts are very common, so you will be getting some good advice before long.
Give that rat Hell
Old May 20, 2017 | 07:53 PM
69L48Z27's Avatar
69L48Z27
You need a garage cat.
Old May 20, 2017 | 07:57 PM
dmaxx3500's Avatar
dmaxx3500
go in the kitchen,unhook the gas line,go get 1.2lbs of c-4,,attach 200' of det cord to a 3.4oz blasting cap,insert cap in c-4,place under vette,using the south door leave the house,walk 175' and light fuse,,hide behind trees,in 38.8 secs,,,,,,,,,,,,,,,,,,,BOOM
now no more rat problem
acuevo's Avatar
acuevo
Give that rat Hell
Glad I got a chuckle out of you I always proof read and think "how can I make this funnier?" The rat will definitely be getting hell!
I hate cats with a passion, but believe me I'm considering it.
Old May 20, 2017 | 07:58 PM
acuevo's Avatar
acuevo
Now do you mean C-4 the explosive or should I go nab the centercaps and emblems off a C4 Corvette? Should be about 1.2 pounds and the guy down the street from me has one LOL.
Old May 20, 2017 | 08:05 PM
doublenut9's Avatar
doublenut9
I spent a dollar at the Dollar Store and bought a box of moth *****. Rats, bugs, snakes, etc., do not like the smell so they leave...Cheap fix and it does not make your car smell. Also, put bounce dryer sheets in your car and it keeps them out of the inside as an extra precaution.
Old May 20, 2017 | 08:16 PM
UM Rebel's Avatar
UM Rebel
I once found a possum resting on my Caddy's Northstar. Ruger .22 took care of that issue
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
OK, that got me too!!
Pretty good movie as well!
http://www.imdb.com/title/tt0469494/
Old May 20, 2017 | 09:08 PM
JR-01's Avatar
JR-01
Traps with peanut butter as bait and glue trays. I don't use poison because sometimes they die in the hardest places to retrieve the remains. Once you get them all, leave a couple of bags of mothballs on the floor under the car. Seems to keep them out of my garage.
Old May 20, 2017 | 09:12 PM
dmaxx3500's Avatar
dmaxx3500
yes c-4/plastic explosives
if you cant find that,try 2-55 gal drums filled with ammonium nitrate fertilizer and diesel fuel,and 2 blasting caps,,but then you will need more det cord
Old May 20, 2017 | 09:45 PM
57gman's Avatar
57gman
Not joking, go spend 20 bucks on 6 pack of Irish spring soap and cut them up and put them in the car, on the engine, on the carpet, in the barrel of the wheels, with the bounce sheets someone else mentioned. And Tractor Supply sells a mouse repellent 4 pack for $14 which they won't like either and your garage will also smell great!
Best 20 bucks you can spend for piece of mind.
Old May 20, 2017 | 10:00 PM
57gman's Avatar
57gman
Originally Posted by JR-01
20 bucks for a six pack of Irish spring? You better go to Walmart.
http://www.walmart.com/ip/Irish-Spri...QbZ6_4rZdZuJ7Y
I'm guessing your wife does the shopping.
Dude, you didn't read what I wrote. Irish spring, bounce and mouse repellent is about twenty bucks. Did you have a bad day?
Old May 20, 2017 | 10:02 PM
Some good suggestions made in the thread. I have always used Bounce dryer sheets in the interior and engine bay and have not had any rodent problems. I do change out the sheets every so often so that they remain fresh and effective.
Old May 20, 2017 | 10:16 PM
JR-01's Avatar
JR-01
Sorry. I guess it was the way you wrote it.
and then:
Old May 20, 2017 | 10:25 PM
acuevo's Avatar
acuevo
Wow, thanks guys. Definitely going to try these suggestions, well... except for maybe dmaxx3500s.
Wouldn't the soap melt under the hood? If you hadn't put "not joking" I definitely would have thought you were trolling me lol.
Old May 20, 2017 | 10:28 PM
Z06_ER's Avatar
Z06_ER
Navigator
I have had good luck with a couple of different things. First and foremost, i bought a couple of electronic traps from home depot by far the best thing, i have killed more of those pesky things electronically than with the stick traps. Also i bought about 10 - $1 rubber snakes at walley-mart and placed then under my vette along with all garage door openings. i have had good luck with this.
Good luck with everything. Kill those BASTARDS!!!
To Rodents in garage
Old May 20, 2017 | 10:34 PM
Crosis's Avatar
Crosis
Old May 21, 2017 | 12:28 AM
striper's Avatar
striper
I have had success with the mouse traps loaded with peanut butter. Also have used cotton ***** soaked with peppermint liquid, it works too. The best seems to be a dufus cat. I say that because if my cat can keep away mice, then any cat can.
Old May 21, 2017 | 09:20 AM
Phanni's Avatar
Phanni
There is a product sold that is essentially a very minty smelling, oil.
It smells kinda like peppermint.
I soak a sponge with it and leave it a couple of places around the garage. for whatever reason, rodents hate that smell and quickly depart.
To me it is not offensive to the smell, but it can be rather strong smelling right out of the bottle. It's cheap, effective, and long lasting.
