Washer fluid dripping from wiper outlets
Old May 20, 2017 | 08:36 PM
rx4arx's Avatar
rx4arx
Default Washer fluid dripping from wiper outlets
So, I recently added billet aluminum screw on caps to dress up engine bay. Since doing so, I am noticing that when I drive on highway and then park somewhere, when I return I have pools of windshield washer fluid under car and can see the fluid 'bleeding' at the wiper nozzles . The cap for the washer resourvoir is pretty tight. After highway cruise, is the heat in engine bay enough to heat up and volatilize the fluid causing it to force back through the hoses and out the nozzles?
Old May 20, 2017 | 10:04 PM
I don't think the engine heat is the problem. I had the same issue when I used to fill the reservoir completely up but then I started filling it only about 3/4ths full and have not had it leak again.
Old May 21, 2017 | 01:50 AM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
I also had that problem when I added a new billet cap. If you have an "O" ring on the new cap, take it off. That fixed my same issue.
Old May 21, 2017 | 05:55 AM
ZigZag's Avatar
ZigZag
The tank needs to vent or will build up pressure from the heat. It happened to me when I added custom caps, it was sealed to tight and couldn't vent.
Old May 22, 2017 | 01:10 AM
rx4arx's Avatar
rx4arx
Thanks guys. I do have an o-ring in that cap. I will remove it and see what happens over the next week or so.
To Washer fluid dripping from wiper outlets
