C5 Battery Charging
Old May 23, 2017 | 02:48 PM
09/Z06's Avatar
09/Z06
Cruising
Default C5 Battery Charging
I've recently purchased a 2003 anniversary edition vert to join my C6Z. I was wondering if I can use my ctek corvette battery charger I bought for the Z on the C5. If so, can you charge in the center console cigarette lighter?
Old May 23, 2017 | 03:14 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
I do that very thing after driving it on the weekends, works keen!
Old May 23, 2017 | 09:17 PM
Don't see why you couldn't use the Ctek charger on the C5. I've never tried charging the battery through the cigarette lighter though.
Old May 23, 2017 | 10:01 PM
ironranger's Avatar
ironranger
I have a CTEK charger is use the cigarette lighter exclusively. Is very convenient and works great!
Old May 24, 2017 | 01:11 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Same here. I have been using the socket under the middle console for the last 4 years with my ctek 7200.
Old May 24, 2017 | 01:12 AM
az57chevy's Avatar
az57chevy
Sure you can. The cigarette lighter is an easy way to REMEMBER to disconnect it before driving off
Old May 24, 2017 | 08:19 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Same here, Battery Tender through the cigarette lighter. And you never forget to disconnect it!
Old May 24, 2017 | 09:44 AM
lonerider2002's Avatar
lonerider2002
Been using mine that way for 3 years now. No problem.
Old May 24, 2017 | 10:01 AM
09/Z06's Avatar
09/Z06
Cruising
Thanks for the responses!
Old May 29, 2017 | 01:02 PM
JJ Bad's Avatar
JJ Bad
7th Gear
I have used this exact same setup for the last year with no problems and I have it plugged into my cigarette lighter also.
Old May 29, 2017 | 04:09 PM
UM Rebel's Avatar
UM Rebel
If you drive it you will not need to put it on a charger..
Old May 29, 2017 | 04:45 PM
doublenut9's Avatar
doublenut9
Did not know I could charge through my cigarette lighter, sure is easier than the way I do it
Old May 29, 2017 | 07:40 PM
o2bnkc's Avatar
o2bnkc
Was this question for real?
Old May 29, 2017 | 07:45 PM
jackthelad's Avatar
jackthelad
If you have a decent battery your C5 can sit for a month or so without a problem. If you run a crappy battery, not so much.
To C5 Battery Charging
