How many miles to reset computer?
Old May 24, 2017 | 03:13 PM
Fast one's Avatar
Fast one
Default How many miles to reset computer?
I have a '98 and it won't pass inspection in New York because the battery went dead during storage so now it has to be driven until the computer resets. So far it's been driven 140 miles and that isn't enough, does anyone know about how many miles are needed to reset the computer?
Old May 24, 2017 | 03:14 PM
Aerovette's Avatar
Aerovette
It's not just distance. It has to do with cycles of information. Variations in driving. Stop, go, turn off, restart, park, drive turn etc.
Old May 24, 2017 | 06:18 PM
Patches's Avatar
Patches
General Motors Driving Cycle
A complete driving cycle should perform diagnostics on all systems. A complete driving cycle can be done in under fifteen minutes.
To perform an OBDII Driving cycle do the following:
1. Cold Start. In order to be classified as a cold start the engine coolant temperature must be below 50°C (122°F) and within 6°C (11°F) of the ambient air temperature at startup. Do not leave the key on prior to the cold start or the heated oxygen sensor diagnostic may not run.
2.Idle. The engine must be run for two and a half minutes with the air conditioner on and rear defroster on. The more electrical load you can apply the better. This will test the O2 heater, Passive Air, Purge "No Flow", Misfire and if closed loop is achieved, Fuel Trim.
3.Accelerate. Turn off the air conditioner and all the other loads and apply half throttle until 88km/hr (55mph) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.
4.Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.
5.Decelerate. Let off the accelerator pedal. Do not shift, touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 32km/hr (20 mph). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.
6.Accelerate. Accelerate at 3/4 throttle until 88-96 km/hr (55-60mph). This will perform the same diagnostics as in step 3.
7.Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.
8.Decelerate. This will perform the same diagnostics as in step 5. Again, don't press the clutch or brakes or shift gears.
Old May 25, 2017 | 01:24 AM
Fast one's Avatar
Fast one
Thanks, that's being printed out for tomorrow. So far I've driven almost 170 miles in three days.
Old May 25, 2017 | 10:52 AM
Crosis's Avatar
Crosis
Wow, if you live in a city thats not even possible to do unless you have a dyno to put the car on. Why did they make it so complicated?
Old May 25, 2017 | 01:32 PM
Aerovette's Avatar
Aerovette
This doesn't have to be all at one time or even in sequence. It just has to happen. This is the shortest path.
To How many miles to reset computer?
