new battery?
Old May 26, 2017 | 12:34 PM
3sACROWD's Avatar
3sACROWD
Hardly anyone thinks about their alternator. The weaker the battery, the harder the alternator has to work. Which would you rather do; replace a battery now or a battery and alternator down the road? Read about the nightmares people have had when replacing their alternator on a C5 and draw your own conclusion.
I prefer to replace my battery.
Old May 26, 2017 | 01:19 PM
bigcypress's Avatar
bigcypress
11+ year old red top battery here and while it hasn't been a problem i think we will replace it this year with a _________ . suggestions for ''O P '' and i welcomed . . .peace
Old May 26, 2017 | 01:39 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Personally, I'd be happy with 8 years and move on.
Old May 26, 2017 | 02:02 PM
C5-SIN's Avatar
C5-SIN
8 years? That's awesome! I'm curious to see what the test results are. How often do you have it off the tender for long periods?
I've replaced mine twice over the last 2 years. Although that's probably my fault. I didn't put a tender on & my beast was parked for over a month. My battery will drain in 3 weeks. Haven't been able to figure out what's draining it.
Old May 26, 2017 | 04:26 PM
Roddy13's Avatar
Roddy13
OP leave it off the tender for a day or two or more and then get it tested. I'd bet at 8yrs old its been on life support thanks to the trickle charger.
At $100 for a battery its worth it in my opinion to replace it at this point ...
Old May 26, 2017 | 05:42 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Best 2 batteries currently available....
Northstar NSB-AGM 34/78
880 CCA
133 minutes RC
4 yr full replacement warranty
Odyssey PC1500DT - 34/78
850 CCA
135 minutes RC
Both made in U.S.A. and neither company is owned or operated by Johnson Controls. Shop around, prices vary.
Old May 26, 2017 | 05:50 PM
JR-01's Avatar
JR-01
880 CCA
133 minutes RC
Odyssey 34/78-PC1500
850 CCA
135 minutes RC
Expensive. I put an Exide 75 in mine 4 years ago and 24K miles for 90 bucks. This year I put that battery in my truck, since it needed one and it still worked OK and bought a new one for the Vette. I use a tender and pull it out over the winter and put it in the basement. I have found I do not need a $250-$300 battery.
