Targa top adjustments
Old Jun 1, 2017 | 08:29 PM
jsilv's Avatar
jsilv
Cruising
Default Targa top adjustments
The driver side latch on my targa top has been coming loose. I've been able to find good instructions on how to adjust the components of the top but I'm a little confused by which adjustment I should make. should I be adjusting the striker (behind windshield trim panel) or the latches on the roof itself?
Old Jun 1, 2017 | 11:02 PM
My advice is try one set of adjustments and see if that works and if not, you can still try the other. I know, Captain Obvious here.
Old Jun 2, 2017 | 11:02 AM
jsilv's Avatar
jsilv
Cruising
Thanks Jack! Thats my plan, I guess Ill start with the striker and see what happens.
Old Jun 2, 2017 | 11:12 AM
Velocity_Vette's Avatar
Velocity_Vette
Since the latching motion of the targa is the moving part that's likely what would need to be looked at first. Indeed, Captain Obvious #2 here saying you'll want to adjust one thing at a time.
Old Jul 19, 2017 | 04:47 PM
jsilv's Avatar
jsilv
Cruising
Just wanted to update this in case anyone has the same issue. Finally had a chance to work on it and adjusting the striker above the windsheld seems to have solved the issue. Its pretty strait forward to adjust, just loosened the bolts and pushed the striker down a little.
Unfortunately when I went out for a celebratory drive the gas gauge died with 3/4 tank so it looks like Ill have something else to work on.
Old Jul 19, 2017 | 05:12 PM
Proletariat designs's Avatar
Proletariat designs
Congrats on getting it fixed.
Try using a fuel system cleaner with techron in it. I will take a couple to 4 tanks to clear up. It may not fix the gauge, but most likely will. I'd try it before replacing the sensor in the tank. Also I think Shell and Exon have techron added to their gas.
Old Jul 19, 2017 | 06:14 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
How did you get the trim out of the way to access those bolts without ruining the trim? I did the rear adjustment, no problem but found those front bolts impossible to access.
Old Jul 19, 2017 | 09:19 PM
jsilv's Avatar
jsilv
Cruising
I have only run Chevron gas since I bought the car 2 years ago and it has Techron in it. I stopped off at the parts store to pick up a bottle on my way home to see if it works. The gauge started working as soon as I cleared the p1431 code.
Old Jul 19, 2017 | 09:22 PM
jsilv's Avatar
jsilv
Cruising
i used a plastic pry bar and was able to move the panel enough to get an open ended wrench on it.
Old Jul 22, 2017 | 07:29 AM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
I was able to get at them and do the adjustments yesterday. Top does not rattle at all now
To Targa top adjustments
