High Beam help newbie
Old Jun 4, 2017 | 10:07 AM
SlimRockett's Avatar
SlimRockett
4th Gear
Default High Beam help newbie
No High Beams,Indicator in Cluster,Or Flash. All fuses are good and circuit breaker they popup fine and stay up with HB switch forward but no lights when I bought the car they worked 4 weeks ago the cluster light has never worked or never has flashed by pulling back.
Old Jun 4, 2017 | 12:40 PM
SlimRockett
4th Gear
I have ordered a new switch for the steering column hope that fixes it!
Last edited by Vetteman Jack; Jun 5, 2017 at 08:18 AM. Reason: No need to quote the previous post when you are the next poster.
Old Jun 8, 2017 | 09:41 PM
SlimRockett
4th Gear
The new switch fixed it!
Old Jun 8, 2017 | 09:54 PM
SlimRockett
4th Gear
Originally Posted by 8VETTE7
Thank you for reporting back the final outcome of your problem. It will likely help others with the same symptoms.....
I hope it helps someone!
To High Beam help newbie
