After one month
Old Jun 4, 2017 | 05:26 PM
old jack's Avatar
old jack
Default After one month
Ok i've owned my 2000 Torch Red C5 for a month now. Will post pictures when I figure out how. I ordered a cover, cup holder and Chadwick's. My wife couldn't believe the cost. Told her I've got to speed money on it, like her to keep it looking good. Didn't go over to good.
A couple things I've notice is every time I drive it, I have to readjust the mirrors, is this normal? I'm going to have to get the 1st to 4th shift bypass. I don't know if the steering wheel lock has been taken care of.
Jack
Old Jun 4, 2017 | 05:41 PM
dbgoodwin's Avatar
dbgoodwin
I belive the mirrors and seat have a memory function so it could be that whenever you drive it it's going back to the default memory. Set everything the way you want it and then set the memory to keep that position
Old Jun 4, 2017 | 05:45 PM
friou's Avatar
friou
If you have an owners manual give it a good read cover to cover. It will address just about all questions regarding the operation and care of your C5. If you didn't get a manual with your car you should pick one up as soon as possible. Good luck with your new baby!
Old Jun 4, 2017 | 07:02 PM
That is most likely the cause of the mirrors moving.
Old Jun 5, 2017 | 12:07 AM
striper's Avatar
striper
Many years of C5 production came with video owner's manuals. You might try looking for one of those..
Old Jun 5, 2017 | 11:53 AM
Velocity_Vette's Avatar
Velocity_Vette
The memory function is the number 1 and 2 buttons on the driver's door. You should have two keys and two FOBs. With everything set as you want you depress whichever setting you want to save, 1 or 2, and each time either that particular key is used or that setting is hit it's settings will be retrieved. What I usually do is set my #2 setting for HVAC (that's stored also) settings so all I have to do is hit that once and my A/C kicks on exactly where I want it.
You can check for column lock very easily. Does your steering wheel lock with key off? If it does then you do not have the column lock recall performed and will need to confirm presence of an aftermarket CLB (column lock bypass) and probably would be wise to carry a 12v column unlocker in your car. If it doesn't lock, then recall has been performed and/or smaller lock plate is present and you only need to confirm presence of a CLB.
Old Jun 5, 2017 | 12:03 PM
knewblewkorvette's Avatar
knewblewkorvette
Jack
The very first 2 mods to do
http://www.complianceparts.com/
http://www.ecklerscorvette.com/corve...kU5BoCzjzw_wcB
Old Jun 5, 2017 | 03:05 PM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
My LH mirror wouldn't hold memory. Tech said it was the mirror but cleared codes on memory and it now works.
Old Jun 5, 2017 | 03:18 PM
Shakeydeal's Avatar
Shakeydeal
If he finds one, he can dig that VCR out of the moth *****.........
Shakey
Old Jun 5, 2017 | 04:41 PM
phoneman91's Avatar
phoneman91
Here is a 2001 Corvette Owner's video--almost as good as a 2000 Owner's video:
Old Jun 5, 2017 | 08:44 PM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Jack
Here is the 2000 owner's manual in case you don't have it:
File Type: pdf
Old Jun 5, 2017 | 09:59 PM
Silverwolf_pup's Avatar
Silverwolf_pup
Jack
Congrats on your C5 purchase! I hate the 1-4 shift it's so stupid! What I do is I try to watch when the light pops up and goes away, what else I do is I get it up to a certain rpm then I drop it into 2nd. There are cheaper ways to bypass it without spending money, so that works with me
To After one month
