first time owner
Old Jun 4, 2017 | 08:12 PM
Fishing128's Avatar
Fishing128
1st Gear
Default first time owner
Just went on trip around lake windbag wis when I got hime put the car in the garage about a hour later started the 1998 corvette and the check engine light came on check the gas cap nothing changed does it take a while to reset it self? Or is there something else I can try
Old Jun 4, 2017 | 08:16 PM
4SUMERZ's Avatar
4SUMERZ
Welcome to the C6 (2005-2013) forum. If you have a 1998, you want to go to the C5 forum for help.
It may take a few cycles to clear if it is the gas cap. It may need a new cap, or it could be something else.
Hopefully the C5 guys that have had similar issues can help you out .
Good Luck
Old Jun 4, 2017 | 09:42 PM
JR-01's Avatar
JR-01
Did you pull the codes?
Old Jun 4, 2017 | 10:01 PM
o2bnkc's Avatar
o2bnkc
Old Jun 5, 2017 | 08:09 AM
If it is the gas cap being loose, then yes, it could take a few cycles to clear the check engine light. But it is a good suggestion to check for any codes on the DIC.
Old Jun 5, 2017 | 08:35 AM
calvins's Avatar
calvins
Oldtimer
When you put the cap back on, turn it to the right until you've heard 3 or 4 clicks. As said before, it may take time to clear. Pulling all of the codes is a good thing to do. If the car is new to you, I'd probably clear them all and start from scratch.
How to check and clear codes:
Record all modules and codes then check the link below for what
the codes are
http://www.digitalcorvettes.com/foru...d.php?p=512062
Welcome to C5's.... you DID post pictures someplace here, right?
To first time owner
