C5 Vert Trunk will not close
Old Jun 10, 2017 | 12:57 PM
destp1's Avatar
destp1
Default C5 Vert Trunk will not close
C5 convertible trunk will not close unless I repeatedly slam it. Trunk pops open just fine. Tried adjusting latch. No dice, same. Any suggestions?
Old Jun 10, 2017 | 01:00 PM
DB1959's Avatar
DB1959
If you have a trunk popper that seems to make it harder.
Old Jun 10, 2017 | 01:07 PM
Fast one's Avatar
Fast one
Have you tried greasing the moving parts on the latch?
Old Jun 10, 2017 | 01:13 PM
DB1959's Avatar
DB1959
No...for me I just think the popper is holding it back as you close it....a door open helps.
Old Jun 10, 2017 | 01:28 PM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
Old Jun 10, 2017 | 01:50 PM
El original's Avatar
El original
WD 40 it. Also there is a metal loop on lid that is adjustable, make sure its is secure. Look to make sure all parts in latch hardware is in place including a spring to lock. If all else fails a good body shop will probably fix for nominal fee. Beats duct taping lid closed.
To C5 Vert Trunk will not close
