[Z06] Zo6 exhaust
Old Jun 14, 2017 | 02:18 PM
snomo66's Avatar
snomo66
1st Gear
Default Zo6 exhaust
Any issue putting Zo6 mufflers on a base Both C5. Have Borla 0038, a little too loud for me I have aging ears....lol
Old Jun 14, 2017 | 03:42 PM
ZO6 cracker's Avatar
ZO6 cracker
No problem at all. I just had my Borla removed and put on my Ti's. Still sounds good because I have headers.
Old Jun 14, 2017 | 04:48 PM
MY03C5Z's Avatar
MY03C5Z
Very popular mod for base c5's, should bolt right up. Once you get the back end up high enough it's a very easy removal and install. Sounds really good with LT's and the ti bypass mod.
Old Jul 3, 2017 | 04:51 PM
540Z28's Avatar
540Z28
Default exhaust swap
Yep, just took a set of Ti off my 04 CE Vert this weekend and put the original back on. Get it up high, put jack stands under it so you can remove the jack AND drop the sway bar.
Old Jul 11, 2017 | 05:19 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Nope...took it to Cheby dealer...30 mins ...lots of twisting involved...$68 labor out the door...
Old Jul 14, 2017 | 11:59 AM
nsogiba's Avatar
nsogiba
Should bolt right up. On an automatic car, you will need to remove the passenger side fuel tank heat shield as it is in the way. Not much harder than on a 6 speed car. Make sure you have the rear end up high, preferably on a lift!
Old Jul 16, 2017 | 10:07 AM
Paul 75 L82's Avatar
Paul 75 L82
Takes 34" to clear on jack stands, that's way up there.
To Zo6 exhaust
