From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Need HELP asap!!!
Can someone take measurements of the front fenders PLEASE!?
Ideally I would need:
1. the length of the fender from tip to end.
2. height from the tallest section after the wheel well from top to bottom.
3. the height of the shortest point in the wheel arch to the top of fender.
4. height of the front portion of the fender where it meets the front bumper to the hood line.
5. and front of wheel well to back of wheel well.
My car is at the track and not nearby for me to do this. Any help appreciated!!!
I got some measurements but I won't guarantee their accuracy, especially since it isn';t specific if you want measurements of the distance in a straight line or along the surface of the fender itself. Also, I don't understand #4. But here goes. I used straight lines projected out from the car. 1) 50" 2) 26" 3) 3 3/4" 5) 30". All measurements are approximate.
Thank you very much good sir, your help is appreciated!
