Outside Air
Old Jun 17, 2017 | 04:37 PM
2ndvett01's Avatar
2ndvett01
Default Outside Air
01 vert with auto/ dual controls. I've scoured the manual to find the settings for only outside air (no heating or cooling). Can't determine settings for this. Any advice?
Old Jun 17, 2017 | 06:46 PM
Ducati Guy's Avatar
Ducati Guy
I had the same question when I first got my toy. This should help:
Press the mode button until the icon shows the air path you want. Turn the driver temp **** all the way left until it shows 60 degrees as the temp - that's the lowest it will go. Adjust the fan speed and turn the AC off. This puts climate control in manual mode. It's a pain to have to turn the AC off every time you do it but that's the way the system is programmed. Note that the fan has to be on for this to work.
Oh yes..........I also printed this and keep it in my glove box. Trust me...you will forget the procedure.
Old Jun 18, 2017 | 09:19 PM
Bob_VII's Avatar
Bob_VII
Actually, adjusting the mode in any way puts you in manual mode, the A/C switch just disables or enables the compressor. But yeah, choose fresh air button, turn off A/C, adjust temp to 60 to keep any air from coming through the heater core.
To Outside Air
