Door Locks
Old Jun 21, 2017 | 04:43 PM
ImpulseIII's Avatar
ImpulseIII
Cruising
Default Door Locks
The door locks on my '01 do not fully engage when I lock the door with the key fob. The interior lock lever only engages about 1/2 way and when I try the outside handle, the alarm sounds. Tried a new battery in the fob with the same results, so....any ideas?? Is there an adjustment or setting somewhere? Thanks in advance.
Old Jun 21, 2017 | 04:52 PM
Velocity_Vette's Avatar
Velocity_Vette
Can you physically lock the lock all the way from the inside for both doors?
As you state it's both doors having the same issue it may be a DIC feature causing the issue. There is a feature through the DIC that will allow auto lock/unlock when the car is in the presence of the key FOB. You typically will hear a very audible click along with DRL flash. Make sure this feature is turned off and then see if that helps. I had to turn it off as the proximity of where I was storing my keys relative to the car would keep locking and unlocking it periodically. I now just use the FOB.
Other than that you could check the connectors inside the accordion wiring for the door, but with both doors having the same issue I don't know if that would actually help.
Old Jun 21, 2017 | 05:55 PM
El original's Avatar
El original
Are both doors having the same issue....?
Old Jun 21, 2017 | 07:27 PM
ImpulseIII's Avatar
ImpulseIII
Cruising
I am having the problem with both doors.
Old Jun 21, 2017 | 07:47 PM
heavymetals's Avatar
heavymetals
From what I gathered, the relays in the door lock control module(s) go **** up.
Ergo the motor for the door lock doesn't get enough juice.
To Door Locks
