Magnesium rims?
Old Jun 25, 2017 | 08:30 AM
colderbythelake's Avatar
colderbythelake
Default Magnesium rims?
Are magnesium rims very desireable? What are the advantages? Thanks!
Old Jun 25, 2017 | 08:38 AM
Murray Anderson's Avatar
Murray Anderson
Depends on the person. An extra charge from the factory if asked for. $1500 I think.
They're lighter than others. Mine has them, love them
Old Jun 25, 2017 | 08:45 AM
colderbythelake
Great looking car! I am looking at a car with those rims.
Old Jun 25, 2017 | 08:49 AM
MSUGTO's Avatar
MSUGTO
I liked the set I had on my FRC, did seem like they were a bit more easily damaged during mounting/dismounting though.
Old Jun 25, 2017 | 09:41 AM
When the magnesium wheels first came out, they were a $3K option. Over the years the price was reduced and at the end of the C5 production, they were about a third of the cost. The big advantage to them was the light weight. However, they tended to chip easily either from rock chips or when tires were mounted/dismounted.
Old Jun 25, 2017 | 09:43 AM
JR-01's Avatar
JR-01
They are lighter. I never had any problem with damage during mounting or dismounting or from rock chips. 75K miles and no chips or damage. Damage may have been caused by inferior equipment at the tire shop.
I am really glad my '01 vert came with them. Love the way they look.
Old Jun 25, 2017 | 10:24 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I think it comes down to subjective opinions on looks.
They are easily damaged. Many say they are lighter and magnesium is a light metal, however compared to the polished thinspokes and some others they are very similar in weight so I don't think there is much advantage there.
Look at post 2 of this thead for the weights.
https://www.corvetteforum.com/forums...ngths-etc.html
These were mine on my '99 FRC.
Old Jun 25, 2017 | 02:41 PM
CQRT's Avatar
CQRT
They're on my Anniversary and are perceptibly lighter IMO. . . .it does appear that they're prone to chips, so I got some touch up paint and a couple coats do the trick.
Old Jun 26, 2017 | 10:47 AM
Gordy M's Avatar
Gordy M
For Mag wheels there is life after death. When they get rock chips, mounting scapes, etc they soon become valuable to the autocrosser. They are 1.5 to 2 lbs lighter than stock wheels and the basic C5 run all 4 wheels and the Z06 use the back wheels on the front, using spacers. They can be repaired and aesthetic but many just go and buy new rims when there get chips and scrapes. If you can save 8 lbs of unsprung weight off the wheels, that is the equivalent of removing 32 lbs of weight. That along with the 16 lb saving with Z06 exhaust remove about 50 lbs of the mass from the vehicle.
Old Jun 27, 2017 | 07:51 AM
nsogiba's Avatar
nsogiba
They're sharp looking wheels. I'm currently in the process of refinishing a square set of 4 rears in a high gloss black to mount on my black 2000 FRC, which had them installed as an original option.
Unfortunately the yellow "MAGNESIUM" logo is long gone, but I will be attempting to reproduce it on a vinyl sticker to reapply, then clearcoat over.
Old Jun 27, 2017 | 08:12 AM
leadfoot4's Avatar
leadfoot4
I definitely like the looks of the OE "mags, and would have gotten them on my C-5, had they not been so expensive......
Old Jun 27, 2017 | 12:05 PM
ZEEZERO-6's Avatar
ZEEZERO-6
Are they lighter then the stock 2001 Z06 rims ?
Old Jun 28, 2017 | 08:55 AM
Gordy M's Avatar
Gordy M
This has been answered dozens of times over the years,
Wheels
19.2 lbs, front; 21.4 lbs, rear - 97-99 OEM wagon - Src
22 lbs, front; 29 lbs, rear - 97-99 OEM wagon - Src
17 lbs, front; 19.5 lbs rear - 97-00 OEM magnesium - Src
18.08 lbs, front; 20.06 rear - 00 OEM standard, thin spoke, high polish - Src
17 lbs, front; 20 lbs, rear - 00 OEM standard, thin spoke, painted, no sensors or centercaps - Src
17.5 lbs, front; 20 lbs, rear - 01 OEM standard high polish - Src
19.6 lbs, front; 21.4 lbs, rear - 01 Z06 forged - Src
19.2 lbs, front; 21 lbs, rear - 02-04 Z06 cast/spun - Src, Src
24 lbs, 18x10.5 - 00+ repro high polish - Src
28 lbs, front; 32 lbs, rear - Z06 chrome repro - Src
23 lbs, front; 26 lbs, rear - Z06 chrome repro - Src
23.5 lbs, front; 24.5 lbs, rear - Z06 Motorsports, polished - Src
20 lbs, 17x8.5, 58mm offset, front; 23 lbs, 18x9.5, 65mm offset, rear - PWO - Src
22 lbs, 18x10.5, 58mm offset, front - HRE 545 w/clear center - Src
27 lbs, 18x12, 74mm offset, rear - HRE 545 w/clear center - Src
24/25 lbs - Z07 wheel weight, front - Src
28 lbs - Z07 wheel weight, rear - Src
Old Jun 30, 2017 | 09:22 AM
K9Leader's Avatar
K9Leader
The Sport Mags came as an original $3000 option on my '99. At the time, they were the only OEM option to the Wagon Wheels. The cost did go down after that. I like the color with Mag Red, black, blue, and white cars (but not so much on other colors - silver, yellow, torch red). When I got my car in 2010, the original set were very beat up - both rears and one front were chipped in many places. The other front was in significantly better shape and just very slightly different in color, as you might get between different runs, so I think that one was a replacement by the original owner. On the forum, I found a set that had been run for a few months and then taken off and stored (after some damage to one of the fronts, which was repaired but not very well) and bought those. I sold my original rears to a guy who wanted them for drag racing. I kept my original fronts, to be restored sometime. After four (or maybe five) years, the "new" set now has some chips. I put the worst of the fronts (the one that had been damaged and repaired) on the right so that if I ever curbed one it would be that one (and I did). Next time I have them rebalanced I will probably put my good original front one back on.
They are lighter, much better looking than the Wagon wheels, and the color looks great with certain body colors, but they damage/chip easily.
-K9Leader
Red cars are faster.
Old Jun 30, 2017 | 09:24 AM
nsogiba's Avatar
nsogiba
They match nicely with that tan top.
Old Jun 30, 2017 | 08:15 PM
ghurst2135's Avatar
ghurst2135
7th Gear
Yeah, I recently got a quote of $150 each to refinish.
Old Jun 30, 2017 | 09:17 PM
JR-01's Avatar
JR-01
Magnesium has some different properties than aluminum, so make sure the shop has experience with it.
To Magnesium rims?
Old Oct 13, 2017 | 09:39 AM
Drew03Z's Avatar
Drew03Z
Nsogiba
Your wheels look more silver than the OEM tan-ish color. did you have them refinished or is it just an effect of the picture?
When you say that you're getting a square set, do you mean that you are going 18 inch on all four corners?
Sorry to hijack the thread. I've got a set that I plan to put on my white 99 FRC, but I think a silver rim may look better on the white than the tan.
Old Oct 13, 2017 | 12:44 PM
typeav's Avatar
typeav
TSW Nurburgring Series Gunmetal
or
Forgestar F14
Old Oct 16, 2017 | 08:35 AM
nsogiba's Avatar
nsogiba
Originally Posted by Drew03Z
Nsogiba
I replied to your PM. That is the original color of the wheels, never refinished as far as I know. They look funny in the picture due to the white balance setting on the camera.
