TRACTION/ABS possibly need EBCM rebuilt
Followed those instructions and fixed mine. Hardest part was getting the case apart.
EBCMs. John Llewellyn is one of them (854-604-0498).
The Lizzard
"I followed the detailed instructions provided by NVUSGT, Bill Curlee and others and successfully repaired my balky EBCM.
Like others, I found that a faulty relay solder joint was the culprit that was triggering warning lights and the C-1214 fault code.
Here's something I will add to NVUSGT's write up, specifically his comment that reads:
"Now in order to remove the case I followed these steps:
1. remove 4 x screws
2. remove silicon from that hole on the back lower corner of the EBCM.
3. use a 2BA (or similar) 'thread tap' to cut a thread in that hole
4. screw matching thread screw/bolt into hole, (it misses pcb inside) until it touches cover plate (screw/bolt needs to be 3" long max).
5. carry on winding the screw in until it starts pushing the cover plate away enough to break that gasket seal and allow space to insert those flat blade screwdrivers and work around the remainder. (Thank You JerseyC5)."
In my case, I used a #8-32 thread tap (bought at Home Depot) to successfully cut a thread in the hole on the back corner of the EBCM. After opening the box with a 2" #8-32 stainless steel screw, I discovered why employing a thread tap was necessary. A combination of silicon and, I think, box wall material were obstructing the screw's path to the plate, and nothing short of a thread tap could have cleared up that path.
FYI, I used a stainless steel screw to reduce the possibility that it would snap off in the EBCM box...a problem noted by an earlier poster to this thread."
The Lizzard
The Lizzard
Probably should of pulled it off when changing out the hp power steering hose last month. But with the nice weather and in a hurry to get it back on the road didn't.
But, will be a project for next winter when it's cool enough for me to want to work in the garage without being in a hurry.
Thanks for all the info on getting it done yourself.
Your car's "intermittent" warning light symptoms are identical to my car's symptoms, at least for the first couple of months. Thereafter my idiot lights stayed on all the time. Re-soldering all of the contact points fixed the problem.
The Lizzard
