Exhaust Detailing
Old Jun 28, 2017 | 06:16 PM
VETTEC599's Avatar
VETTEC599
Default Exhaust Detailing
We've owned our C5 for almost 10 years. It came with a Borla exhaust. As a DD we have taken care of it both inside and out. The one sore point is the exhaust. We can bring out the shine easily except for the spaces between the BORLA. Looking for a way to get the area between the letters looking as good as the rest of the exhaust. I've tried a tooth brush, I've tried different cleaners - nothing works. From a distance it looks OK, but I know it's there! Any suggestion appreciated!
Old Jun 28, 2017 | 06:42 PM
RVETTE42's Avatar
RVETTE42
Pics would help but I assume you are talking about the tips where Borla is stamped in to the them. Make sure your using a good quality metal polish like Adams. A regular car polish or wax will not usually get the job done.
Old Jun 28, 2017 | 06:54 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
BlingMaster Aluminator
Old Jun 28, 2017 | 07:05 PM
VETTEC599's Avatar
VETTEC599
Thank you - yes, the tips where the Borla is stamped
Old Jun 28, 2017 | 07:25 PM
Fcar 98's Avatar
Fcar 98
Old Jun 28, 2017 | 07:31 PM
Try Adam's metal polish or even Mothers polish.
Old Jun 28, 2017 | 07:56 PM
Dark Sarcasm's Avatar
Dark Sarcasm
Lots of different methods but they all have a common denominator - work in stages. Most aggressive to least aggressive. If you use sand paper start with a 320 or 600 grit. Work your way up to a 1500 - 2000 grit. This is if you want it to be mirror shiny. Finish it off with a Mag wheel polish like from mothers. If all you want is factory clean and shiny you could use a #0000 steel wool and some aluminum polish, such as mag wheel polish.
Old Jun 28, 2017 | 09:52 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Whenever I was faced with a difficult piece to bring back to a shine I have used Simichrome or Flitz polish. Use sparingly and in small areas. As noted, polish will not remove pits and marring so you need to prep the metal first to a smooth finish and then finalize with the polish.
Old Jun 28, 2017 | 10:12 PM
v8srfun's Avatar
v8srfun
The best metal polish I have ever used is 3m marine aluminum polish nothing else comes close. I mean it is far superior to amy other products I have ever used!!!
Old Jun 29, 2017 | 04:10 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Take the cat back off the car and hit it with a buffing wheel. That's what I do. Looks much shiner than when I opened the box for the 1st time.
Old Jul 5, 2017 | 01:48 AM
JacobVrrm123's Avatar
JacobVrrm123
What I've always used was 0000 steel wool first than finish it with Mother's Polish. I used to work at a body shop so I learned all the tricks lol.
Old Jul 5, 2017 | 06:16 AM
runner140*'s Avatar
runner140*
Bartenders Friend works for me. My wife uses it on kitchen stainless steel...refrig., ovens, microwave and dishwasher.
Old Jul 5, 2017 | 07:18 AM
02MillenniumVette's Avatar
02MillenniumVette
I've always used Mothers Mag Polish on mine. It takes a little work to get it done but it comes out great.
Old Jul 5, 2017 | 03:47 PM
stingray71's Avatar
stingray71
I would try a powerball and Mother's Mag & Aluminum polish
https://www.walmart.com/ip/Mothers-P...nsion/15137628
To Exhaust Detailing
