Just Curious, run flats, again
Popular Reply
As I've said many times... everything is a trade off. Want the safety factor of a Rub flat? you will be giving up ride, and tire longevity.
As Far as GY vs. any other manufacturer of run flats, there are no secrets... No one complains about GY run flats on a Brand new car.. No One..... the original GY run flats had a 200 mile zero pressure warranty. 2nd gen GY run flats had a 50 mile zero pressure warranty. 2nd gen was better than first gen. but then you gave up the safety factor of 200 miles for 50 miles... " Everything is a trade off.
Buy run flats ( any Brand ) and the life expectancy of the rubber compound to stay pliable without noticeable performance stability is about half of a conventional tire with a softer sidewall, and a much cooler operating temperature.
Its just how it is...Don't be fooled by those who buy New Run flats and say they are better. They are only better because they are New and have not been subjected to the heat that is associated with run flats. Run flat design coupled with 140 F. blacktop highways and road surfaces, will turn those New run flats into hard crispy critters, faster than you would like. Most people go into denial and put up with the eroding handling factor of hard rubber found with run flats that have been aged by above average heat which occurs naturally in any run flat tire because of its design..
I know a few things because I have seen a few things.
Stuck with run flats as when I do drive it usually involves very busy interstates and I want to be able to get away from the various sleepy or distracted souls out there before I try to pump up a tire. Especially at night. People get run into on the hard shoulders around here with grim regularity.
Besides, to paraphrase "Engines Charlie", what's good enough for General Motors is good enough for me - and all Vettes have had runflats as OEM since the demise of the C5 Z06.
FYI... When you buy a Bugatti Veyron.. you had your choice of Michelin or GY run flats. they cost 24,000 dollars a set... yes 24,000. and they last anywhere from 15,000 to 24,000 miles. no room for a spare in a Veyron either. Of course it takes very special tools and a Bugatti field tech to change them...he comes to you...you pay all costs..
The problem with run flats is most people " think " conventional tires and all that goes with that. Since I left GM, I've been saying all along here on this forum.. " Everything is a trade off. " many people who choose run flats want the peace of mind and are willing to dump them at 20K because they are not 40,000 mile tires.
Lots of people are wanting conventional tire performance and longevity but with the added feature of run flat technology... Everything is a trade off. So that is not going to happen any time soon.
On a side note, my 58 fuelie Corvette got 12 miles to the gallon.. Corvettes are getting much better at this mpg thing... today. Sometimes technology can advance but it's fairly tough to bend the rules of physics.
The sun, UV rays, a Georgia black top road in Mid July with ambient around 101* F. and that road can fry an egg. Non flex sidewall construction of a run flat can multiply the cooking process to the point of increased internal psi of a tire by as much as 35 % over design spec, only adding to the heat, also decreasing the foot print due to over pressure... too many people check tire pressure cold... look at a run flat at operating temperature on a 95+ day and see where that 30 psi cold actually is. 38/ 39 psi, only adds to the problem. We tried to idiot proof this car and yet peoples still use low octane fuel, read the tire sidewall and put 63 psi in the tire because it says max pressure 63 psi. the idiots think that more " Has to be Better " GM spent a significant amount of R&D time and money to design an OLM system so your motor can last far past the certification set for an LSX motor, yet many do not use it.
Don't blame GM for making a world class car, that just too many people do not understand. Nothing out there compares dollar for dollar and what you get for that dollar.
Don't ask run flats to do what conventional tires do... they are not the same thing.
Lastly, no one buys a 70K C7 and goes back to the dealer bitching because their brand new car handles poorly because of the run flats.
RF's continue to get better. Give it another 10 years and non runflats will be the exception.
I can tell u my next set will NOT be run flats! Looking at toyo R888 or pilot sport cup2 or MickeyThompson's new cheater slics,
sorry for the hijack
One stupid question - the garage only put 30 pounds in them. I thought they were supposed to be 32? I don't suppose 2 pounds matters much though. Pressure goes up a few pounds after they warm up.
