Need advice on cam head combo
Location: ALL governments are legalized mobsters, so doesn't matter where I live :(
Hi guys,
I'm going to be installing an LS6 cam from an 02 z06 that a friend gave me, but what do I need to do to my 241 heads to match the cam? Other then LS6 yellow springs, do I need new lifters, and rods?
Also, what is a good oil pump for this setup? I've read about ported out OEM pumps, but not sure where to get it from.
Any advice appreciated.
i would pass on and stock cam. any aftermarket cam would be better. if your limited by budget like i am. you just need to save up and get quality parts. depends on how far you wanna go into your engine will determine whan you should replace. i just posted my build progress. its not a full out performance built as im limited by budget. forged pistons and rods with stock crank. it will be good for way more power than im making.
Nothing. The LS6 cam is pretty small, and like above, I wouldn't bother. However, if you wish to maximize the parts you already have, I would have the heads milled for more compression, or maybe shop around for take-off 243s. I sold my stock heads for $600 about 9 years ago.
That being said, from what I've read the LS6 cam will not work well with stock 241 heads because of the extra lift that could do damage. This is why I'm asking what else I would need to do to my 241's to work with this cam.
I'm looking at that option as well, but the future of my car is uncertain at this point since I'm not sure I'll be keeping after the summer ends. In the meantime it's going in for a new damper and oil pump, hence why I just want something simple and easy.
I admit I'm not familiar with 241 heads, but the LS6 cam's lift is not that much, and I really don't think it's an issue.
STALION (07-10-2017)
Banned Scam/Spammer
Received 1,319 Likes
You DO need to put on LS6 valve springs (or other aftermarket) to use the LS6 cam. Otherwise there's nothing else needed. Since you have the springs off I'd change the valve stem seals.
Personally I wouldn't waste my time with a stock LS6 cam. You can buy used cams 1/2 price and a set of new Comp 918 springs aren't much.
Received 1,261 Likes
I agree with the others that say to go with a better cam, there isn't much difference to justify doing all that work in my opinion but if it's what you want to do so be it... definitely measure the pushrod length after you have the cam installed... the ls6 cam was ground on a smaller base circle and the z06 243 heads used slightly longer valves to make up the difference for the smaller base circle so that's why they use the same length pushrods that the ls1 uses... since you will be using 241 heads most likely you will need a slightly longer pushrod, it's not much something like .025 longer but if you do need them and just throw your pushrods back in you might have more valvetrain noise and not enough preload on the lifters... also do new springs, valve seals, oil pump, timing chain, and also consider doing a trunnion upgrade while everything is apart, and then you will need a tune... after all that is said and done you will have spent a good chunk of money for not a lot of power, just not worth it to me personally
OK...change of plans. Looks like the cam I will be getting out of my friends car is not the LS6 after all. It's a comp custom grind cam that was used in a z06 and stock heads. It dynoed at 425hp (not sure of the trq specs).
My engine has 105k
Work being done so far:
Power bond PB1117N harmonic balancer
Melling M295 oil pump
OEM timing chain sprocket (upper/lower)
OEM chain dampner
Hinson C5R timing chain
I'm working not only on a budget, but time constraints. What I need now is to figure out just how deep I need to go on the heads. So far suggestions have been good, so tell me if this sounds right:
Valve springs (dual springs with guide seals and hats) or if someone can recommend a complete kit where I don't have to remove the heads (if possible).
at this point not sure what else...keep in mind budget.
My engine has 105k
OEM chain dampner
you will probably be happier with that cam, does your friend know the specs?... that will help you with spring selection... I agree that if you can splurge for a set of 243/799 heads that will definitely be a good idea but if it just isn't feasible at the moment you can get away with just doing springs on your 241 heads, just be aware that you will be somewhat choking the engine... the rest of your parts list looks good... I didn't see it posted but in case I missed it somewhere do you already have headers?... if your car is pre 01 have you put an ls6 intake on it yet?
These are the cam specs...
I did some research and I may just freshen my heads but other then springs/ retainers not sure if I would need new valves as well and connecting rods as well. Would I need new Rocker and arms? Thoughts?
Medium/large cam on stock heads. Lift is high enough to need the best springs you can buy. I think you meant to say pushrods, not connecting rods, and you can probably do without them in favor of budget, and needing other things more. BTW, you might need to check for piston to valve clearence. You're going down an expensive road, just so you know.
I'm still learning about pairing cam to head combo, so can anyone recommend a spring kit with specs with the cam I posted?
St. Jude Donor '17-‘18-'19-'20-'21-'22-'23-'24
The cam you reference is going to need good dual springs. If you are sure you are using the 241 heads then I would suggest contacting a few of the vendors you'll find here on the Forum. Explain to them your set up (heads, cam) and let them make recommendations. Unfortunately, I'm not aware of anyone who manufacturers a good, quality spring set up that is really inexpensive. I'm sure you are aware, a quality set of springs is a lot less expensive than an engine rebuild if cheap springs drop a valve.
STALION (07-21-2017)
