Clutch Pedal Return Spring?
Old Jul 12, 2017 | 02:18 PM
huesmann's Avatar
huesmann
Default Clutch Pedal Return Spring?
The past couple of days my clutch pedal has felt less "return-y" than usual. The first time I release the pedal it feels slow to return to the up position, and during the rest of the drive it feels just a smidge less springy than usual. Fluid level in the master looks good. Is this common?
Old Jul 12, 2017 | 02:40 PM
El original's Avatar
El original
There is a return sping loaded above pedal. If it broke you will find half of it on the carpet below pedal. Can be replaced easily and is cheap (DIY). I heard it has little to do with pedal return and many are not replaced if broken. So I do not think this is your problem but check in any case. Other members will help you there. Good luck, Rob
Old Jul 12, 2017 | 02:50 PM
zeevette's Avatar
zeevette
Yes, that spring breaks easily. It isn't a return spring, it actually assists you when you press the clutch in. It also serves some function regarding pedal position.
Old Jul 12, 2017 | 02:54 PM
usgecko's Avatar
usgecko
St. Jude Donor '13,'14
Good luck - mine started acting like that and gradually got worse - the slave and master cylinder both needed replacing
Old Jul 12, 2017 | 05:17 PM
Cha_Cha's Avatar
Cha_Cha
I have a few brackets and springs to help pedal return to fully engaged position if interested.
https://www.corvetteforum.com/forums...pring-kit.html
Old Jul 13, 2017 | 02:42 AM
JacobVrrm123's Avatar
JacobVrrm123
Start by replacing the clutch master cylinder with a Tick one, that's what I'll be doing.
Old Jul 13, 2017 | 04:47 AM
o2bnkc's Avatar
o2bnkc
Very nice!
Old Jul 13, 2017 | 01:07 PM
huesmann's Avatar
huesmann
Master and slave were both replaced during a clutch swap last fall.
Old Jul 13, 2017 | 01:14 PM
MY03C5Z's Avatar
MY03C5Z
I removed mine after I got it, makes for quicker shift times
Old Jul 13, 2017 | 02:14 PM
JacobVrrm123
I did the same recently I love it way more without it.
Old Jul 13, 2017 | 07:40 PM
cadwiz_01Z's Avatar
cadwiz_01Z
Veteran: Marine Corps
From: When Democracy becomes tyranny, the armed citizens will still get to vote!
Mine was broken when I got it. I replaced it and it broke again recently. My pedal has never felt/acted as you have described.
To Clutch Pedal Return Spring?
