A/C oil leak
Old Jul 14, 2017 | 09:05 AM
JohnnyDee's Avatar
JohnnyDee
2023 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (performance mods)
2017 C5 of the Year Finalist
Default A/C oil leak
I've noticed some oil on the spring and cross member under the AC compressor on my '99 FRC. I have a lift and have looked everything over and cannot find any other place it could be coming from. The AC still blows cold. Is there anything I can do short of replacing the compressor? Thanks
Old Jul 14, 2017 | 09:51 AM
ericdwong's Avatar
ericdwong
Sure it's not your power steering rack or one of the hoses? I'd put the dye stuff into the AC and power steering fluid (probably P/S first), wait a few days then hit it with the black light. Also in my experience with the leaky A/C mine leaked out from the the compressor seals and under blacklight with the dye you could see it evaporated and left deposits in a ring shape around the compressor, but did not "drip" out. My guess is it's likely not the A/C compressor.
Old Jul 14, 2017 | 10:13 AM
helga203's Avatar
helga203
this is what happen to me. Found it with the dye.
Old Jul 14, 2017 | 10:21 AM
JohnnyDee's Avatar
JohnnyDee
I had a drop of oil on the bottom of the compressor itself and I don't see anything above where it could be coming from.
Old Jul 14, 2017 | 10:45 AM
ericdwong's Avatar
ericdwong
oh ok- I'd still recommend the dye so you can be sure.
Old Jul 15, 2017 | 07:11 AM
1blkc4's Avatar
1blkc4
Im dealing with the samething I just put some dye in the ac but i think it looks like motor oil .
To A/C oil leak
