Code 1214
Old Jul 16, 2017 | 05:03 PM
Booger789's Avatar
Booger789
Default Code 1214
I have been getting it on startup for about 2 weeks but it would usually go away after a thhe car warmed up and I restarted it. Yesterday's drive it did not go away at all. I pulled it today going to abs fixer tomorrow. I am pretty sure that will take away my problem. It was not actually to Bad pulling it myself.
Old Jul 16, 2017 | 07:36 PM
001pewter's Avatar
001pewter
St.. Jude Donor '17-'18
https://www.corvetteforum.com/forums...r-fleabay.html
It's not really that hard to fix youself. I used this thread to repair mine. Hardest part was the the case separated.
Old Jul 16, 2017 | 08:16 PM
NSBC5's Avatar
NSBC5
A failed wheel hub assembly or bad plug connection at the hub can throw that code. Start with the front right wheel hub assembly.
Old Jul 16, 2017 | 09:57 PM
Booger789's Avatar
Booger789
Battery is new about a month old reading about 12.5 n my fluke. All connectors look good. And are in good shape. Not 100% on all the grounds.
Old Jul 17, 2017 | 06:12 AM
NSBC5's Avatar
NSBC5
8vette7 may be on to something. If there is anything I have learned from this particular forum, it is that members who post replies seem to know more than I do about C5 Corvettes. I just went through the same thing Booger789 described. After looking over the car, using the Y-body FSM's to trouble shoot the multiple fault codes and thinking about when the codes and warning lights popped up, I replaced the front right hub. Problem solved. However, my initial thought was, in fact, a bad EBCM was the problem. Good luck Booger789.
Old Jul 17, 2017 | 08:32 AM
MikeG37's Avatar
MikeG37
Old Jul 17, 2017 | 09:55 AM
JR-01's Avatar
JR-01
This is some new information for me. When I had the 1214 code a couple years ago, everyone told me my EBCM was bad. I replaced it and all is well. I guess I was lucky it wasn't something else.
Old Jul 22, 2017 | 08:26 AM
Booger789's Avatar
Booger789
Well I got my Ecbm back from Abs fixer. Installed and all codes cleared. Went for spirited drive and now getting code c1228h. Which means passenger rear excessive wheel speed variation. I cleared code and drove normal for awhile but the light and code comeback. I will check wiring, but this looks like I am gong to have to replace hub. Is that a proper diagnosis if wiring is in good shape.
Old Jul 22, 2017 | 09:20 AM
001pewter's Avatar
001pewter
First paragraph of post#4.
Old Jul 22, 2017 | 10:23 AM
Booger789's Avatar
Booger789
I will get it taken off today and report back. Can not thank you all enough for the help of this forum.
Old Jul 23, 2017 | 11:37 AM
Booger789's Avatar
Booger789
I took off both rear wheels and checked the connectors. None looked bad, but I used some cleaner, sprayed both ends down to clean the connectors, reassembled everything and have been on a couple drives now. I am happy to report I am abs light free and all seems good to go. Thanks for the help everyone.
Old Jul 23, 2017 | 11:44 AM
001pewter's Avatar
001pewter
good to hear you got it going.
To Code 1214
