Body side moldings
Body side moldings
I am considering buying a C5, can the body side moldings be pulled off relatively easy? Will it leave a mark or will the paint be a different color underneath?
It depends.
If the car has been stored inside then it likely isn't going to leave a mark. If it has some mileage on the car it's very possible the underlying paint will appear darker than the surrounding paint. Effectively it's a crap shoot, and at best if there are issues once removed you may inquire with a good detailer or paint correction specialist.
They're attached with body tape so there are no bolts or nuts to remove.
I pulled them off of my black 99 shortly after I got it. After nearly 20 years I think most will leave some amount of "shadow". Mine did but its barely noticable (was garage kept by previous owners and very clean). Eventually I'll be doing chadwicks paint correction and I'm hoping that will sort it out.
I noticed it on my car, getting the adhesive off was a pain but I got it done. Had a friend go over the area with a polisher and cutting compound, can't tell at all now. Car had around 81K when I removed them, 2004.
Received 2,707 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
If it doesn't work out, they can always be put back on.
Received 19,307 Likes
'20-'21-'22-'23-'24
