install LED lights to foot well lights
I want to replace the 194 bulbs with LED'S in my 1998 Corvette Coupe in the foot well area to get more light to the floor area. I was told in order to that I would need to add resistance to circuit or they will not work. Can anyone help me with some advice?
woodie
woodie
Received 2,708 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
woodenr (07-27-2017)
Received 1,679 Likes
^^ Yep (I agree with post #2 and #3)
Banned Scam/Spammer
Location: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Received 3,916 Likes
Buy them on ebay, I got a set of 4 for less than $2 shipped. Here's a link, and pick out bulbs that have as many LEDs as possible on them (the more, the brighter):
https://www.ebay.com/sch/i.html?_fro...94+led&_sop=15
You can use the extra two to do your trunk/cargo area lights.
If interested, I'm selling my corvettes interior LEDS as well as reverse LEDs.. Used them for about a week, so they're still new. Check out the parts section or email me if interested.. they are from Radioflyer..
St. Jude Donor '17-‘18-'19-'20-'21-'22-'23-'24
I believe you're thinking of the need for a resistor or other means of putting a load on the circuitry for flashing lights (such as turn signals) so the computer doesn't misinterpret the lack of load as a burned out bulb and flash the lights quickly which is typically done to advise of a burned out bulb.
Received 3,812 Likes
You have several options, you can replace the existing bulbs with LED, if you want more light, you can integrate led strips ( found at most Auto parts stores.).. you can choose 8 in. 12 in. 18 in etc. That's what I did. I put a couple of strips in the hatch area.. the strips can be put out of sight, and make a dramatic difference.
'23-'24
Or you can make them yourself like I did.
See post 2 on how bright they are.
[QUOTE=Choreo;1595235356]I did "both" - replaced the bulbs with LEDs and added 12" strips. Also added LED strips along the door bottoms and along the sill plates. I pretty much only drive and park at night, so they are big help.
Nice set up
Nice set up
