[Z06] GHL Bullets Vs Corsa Extreme
Old Jul 31, 2017 | 07:19 AM
jumpmanmb87's Avatar
jumpmanmb87
Default GHL Bullets Vs Corsa Extreme
Currently running GHL bullets on my car and have had zero complaints I love it but I'm looking to maybe try Corsa extreme. Any pros and cons between the two? GHL has a very deep done.
Old Aug 4, 2017 | 11:50 PM
MSUGTO's Avatar
MSUGTO
I'm deciding between the two as well but I'm not able to find any GHL distributors to compare pricing. Any hints on where I should look?
From what I've noticed is that the GHL bullets are a bit louder than the Corsa Extreme but with a deeper sound where the Corsa is a bit higher pitched.
Old Aug 5, 2017 | 12:31 AM
StingrayRebel's Avatar
StingrayRebel
both are great exhausts and the same two I considered as well... I wanted max power and least restriction and with that being said I ended up going with corsa xtremes because the design seems more free flowing and less chance of restriction since the exhaust doesn't flow directly through the mufflers and also has a straighter path to where it exits... I do like the ghl tips better though... ghl is no longer available new and you will have to keep your eyes open in the for sale forums if you decide that is the one you want... as far as the ghl being louder I'm not so sure about, maybe at idle and cruise they are louder than the xtremes but wide open I think the xtremes would be louder
Old Aug 5, 2017 | 12:35 AM
pjdbm's Avatar
pjdbm
I was just checking that exhaust out and happen to thin it was the best sounding yet, too bad they are no longer making them.
MSUGTO's Avatar
MSUGTO
Thank you for the heads up, seemed odd that I couldn't find GHL anywhere online.
To GHL Bullets Vs Corsa Extreme
By Michael S. Palmer | 2026-06-03 11:00:24
