Codes
Old Aug 6, 2017 | 01:32 PM
C52002Vert's Avatar
C52002Vert
Default Codes
Ok last night I went over a bridge and it had a couple of sharp bumps on it and my service traction and abs lights came on. I looked the codes up and found what they meant. All is right now, I think that there is a connection that lost contact for the .23 seconds that it took to throw the codes. Where is the best place to start looking for a loose connection? I already wiggled the wires on the controller and they are tight, anywhere else that should be addressed? Thanks in advance for any advice!!
Old Aug 6, 2017 | 01:42 PM
jcgunn's Avatar
jcgunn
Check the four wheel speed sensors
Old Aug 6, 2017 | 01:59 PM
C52002Vert's Avatar
C52002Vert
Thanks but this is the code that I got when I pulled them?: C1214 Sol Valve Relay Contact or Coil CKT Open. I read that the controller is the problem and probably a bad connection somewhere?
Old Aug 6, 2017 | 02:25 PM
C52002Vert's Avatar
C52002Vert
Thanks I saw that thread and I am not sure I want to tackle that with it happening only once but if it continues to happen (and I have read that it will be back) I'll have to do something. Was just hoping for something simple before doing that.
Old Aug 6, 2017 | 05:02 PM
C52002Vert's Avatar
C52002Vert
Thanks for the quick reply's and the words of wisdom! This is why this forum is the best I have found, most of the reply's that I have gotten are of the good kind like yours. Again THANK YOU
To Codes
