Remove radiator
Old Aug 7, 2017 | 04:07 PM
Best210's Avatar
Best210
8th Gear
Default Remove radiator
I have a Novi 2000 supercharged C5 and the plastic tank on the side of the radiator is cracked. I need to replace the radiator my question is do I have to remove the head unit of the supercharger for the radiator to have clearance to come out? Thank you in advance!
Old Aug 7, 2017 | 08:20 PM
StingrayRebel's Avatar
StingrayRebel
probably, that company uses a different cradle that tilts the radiator at more of an angle which puts it pretty close to the blower and sometimes you have to trim the fan shrouds to clear the blower outlet... if you had a lift you could take the radiator cradle off and probably get it out through the bottom but you would need to support or remove the intercooler as well
Old Aug 7, 2017 | 09:02 PM
Best210's Avatar
Best210
8th Gear
Thank you!
Old Aug 7, 2017 | 11:37 PM
Sounds like quite a bit of work - good luck.
To Remove radiator
By Michael S. Palmer | 2026-06-03 09:39:05
