cold starting?
Old Aug 8, 2017 | 10:59 AM
royal flush's Avatar
royal flush
Default cold starting?
First start-up takes afew seconds to start compared to when motor is warm-normal?
Old Aug 8, 2017 | 11:29 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
mine fires right off always, maybe you have a bit low fuel pressure ?????
Old Aug 8, 2017 | 11:49 AM
royal flush
I hear the fuel pump go on--i think im thinking alot bigger deal than it really is--its about maybe a second longer to fire compared to when motor is warm and fires instantly
Old Aug 8, 2017 | 12:12 PM
dbgoodwin's Avatar
dbgoodwin
i suspect this as well.
I actually prefer the way both my corvette and my toyota pickup start in the cold, they fire up so fast in the warm that it doesn't even make the cool starter sound
Old Aug 8, 2017 | 12:22 PM
JR-01's Avatar
JR-01
Originally Posted by 8VETTE7
On a cold start try turning the key to the ON position for a few seconds and listen for the fuel pump (behind your head) to stop running. Then see if the car starts right up. If yes, then the fuel pressure is bleeding off after the car sits for a while and the pump takes a few seconds to bring it back up to around 58lbs.
Is there a check valve or something in the pump to hold pressure after engine shut off. Does the pressure bleed back into the tank? Sometimes mine takes a couple seconds to fire after sitting for awhile, too. I try to let the gauges sweep before engaging the starter. That usually works.
Old Aug 8, 2017 | 12:26 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
the injectors can drip or bleed off !!!
Old Aug 8, 2017 | 12:28 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I hardly ever hear my starter, love it when I turn the key and instantly hear the exhaust come to life !!!!
Old Aug 8, 2017 | 01:33 PM
royal flush
Fuel pressure @ 58 lbs. Yes there is a check valve in a rubber line from the fuel filter to the tank that hold pressure to the injectors--i had my replaced few years back--mine is 01 z06--again its 1 second longer than instant start-Im being pickey-maybe needs injector cleaner-
To cold starting?
