map lights
Old Aug 12, 2017 | 02:43 AM
reshar17's Avatar
reshar17
4th Gear
Default map lights
2004 C5 map lights, visor lights and mirror darkening stopped functioning
Old Aug 12, 2017 | 03:24 AM
Tsumi's Avatar
Tsumi
Most likely blew a fuse. Check your fuses in the passenger footwell compartment. I don't recall which fuse it is, someone else can probably chime in.
Old Aug 12, 2017 | 03:57 AM
Mickeyrx70's Avatar
Mickeyrx70
Check fuse #21.
Old Aug 12, 2017 | 11:08 AM
001pewter's Avatar
001pewter
St.. Jude Donor '17-'18
If its not the fuse wiggle the wires on the back of mirror. I had same sounding issues and its a bad connection.
Old Aug 13, 2017 | 12:32 AM
glfrmrk's Avatar
glfrmrk
I have been having a similar problem. I was blowing the fuse #21 I think. I have had to replace the fuse four times, then removed and reattached the ground connection on my hi-4 relay (keeps all four headlights on when hi beams are on) and now the green light (a sensor?) blinks as well as the yellow lights that point at the shifter. The mirror does not dim. I will see what happens if I remove the hi-4 relay completely.
To map lights
