No Start - 01 Vette
Bought new battery, then starter, and still same problem.
Replaced ignition switch (Amazon $64.00) and that solved the problem.
Bob.
I had hoped just lowering it a littler would be enough, but no, it had to be disconnected completely, and that includes the rear section, at least enough in the rear so the front exhaust is lowered to the ground.
Bob.
Bob.
Actually the starter did not need to be replaced, but it was a process of elimination.
When the engine wouldn't turn over, and the dic said low voltage, I assumed it was the battery, so I put a full charge on it, and still nothing, so I bought a new one.
Still it wouldn't turn over, so that is when I replaced the starter.
Still it wouldn't turn over.
In desperation, I got really pissed, and turned the key off and on a couple of times,("start you bastard") and the engine fired right up.
Shut it off, and nothing, screwed with the key again, and fired up.
Replaced the ignition switch, and everything has been ok since.
Bob.
Bob.
