Wheel Sizes and Offsets
Old Aug 14, 2017 | 06:42 PM
J Anz's Avatar
J Anz
Default Wheel Sizes and Offsets
Hi all this is my first post in a while so please bear with me.
I am looking to upgrade my wheels on my 2002 C5 Coupe. I am looking to stay with factory sizes 17x8.5 and 18x10.5. The wheels I am looking at are the 2009 C6 ZO6 Spyder wheels that are made to fit my C5 in the factory sizes. The factory offsets are different from the aftermarket wheel's offsets. Does this make a difference even those the size of the wheel matches the factory sizes.
Thank you all in advance,
J
Old Aug 14, 2017 | 08:33 PM
6speedsteve's Avatar
6speedsteve
What offsets are listed for the wheels you are buying?
Old Aug 14, 2017 | 08:39 PM
J Anz's Avatar
J Anz
Front is +56, Rear is +57
J
Old Aug 14, 2017 | 08:56 PM
6speedsteve
The front is ok, the rear looks like you lose .400 on your offset & you gain .500 with the wider wheel, so the rear would push outward .900
Old Aug 14, 2017 | 09:00 PM
J Anz's Avatar
J Anz
Ok, so they will fit the factory tires without fitment issues or needing any type of adapter?
J
Old Aug 14, 2017 | 09:17 PM
6speedsteve
Correct, no adapters needed, what size tire are you running on the rear? a 10.5 would normally be a 295 width tire.
Old Aug 14, 2017 | 09:21 PM
J Anz's Avatar
J Anz
Thank you for the help!
I apologize I meant a 9.5 for the rear That was a typo. My factory tires are still good so I would be running 245's up front and 275's in the rear.
J
Old Aug 14, 2017 | 11:29 PM
6speedsteve
The rear would only be out 8mm or about .300 then so that would be fine, depending on how the overall width of your tire is when mounted it may actually be flush to the fender.
Stock Goodyears run wide a rear 275 when mounted on a 9.5 rim is 11.25 overall width.
Old Aug 15, 2017 | 10:16 AM
Gordy M's Avatar
Gordy M
The stock C5 offsets for the 17x8.5 is +56 and for the rear 18x9.5 it is +57. So the wheels you are buying have the correct offsets for your car.
Old Aug 15, 2017 | 12:31 PM
6speedsteve
The info on that chart is incorrect, the front is 58mm offset, the rear is 65mm offset, it is stamped into the back of the factory rim.
The front rim he is looking at is fine only 2mm difference, the rear rim is 8mm difference which is .300, that will push the rim out .300 but will still fit fine.
Old Jul 24, 2022 | 03:33 PM
2002 C5's Avatar
2002 C5
I know this is an old thread, but during my research I found this thread, it would not be good if someone did the same and used the wrong information. It will depend on rim diameter and width. The chart I attached shows the vast differences.
File Type: docx
To Wheel Sizes and Offsets
