Top Adjustable??
Old Aug 16, 2017 | 09:10 PM
crazeejames's Avatar
crazeejames
2nd Gear
Default Top Adjustable??
New to me 2000 Vert, adjusted the top today so driver door doesn't rub top at corner, but also notice the top doesn't sit flush with the deck on the drivers side, but seems to on the passenger side. Is there an adjustment for this? Tried #5 bow adjustment, but that is for the more rear part of the top. See pics for better explanationName:  TOP  (1).jpg
Old Aug 17, 2017 | 10:39 AM
Hotrodzz3's Avatar
Hotrodzz3
Here's an article on how to adjust the top.
http://www.c5forum.com/forum/ubbthre...te_id=1#import
Old Aug 17, 2017 | 06:20 PM
UM Rebel's Avatar
UM Rebel
Originally Posted by crazeejames
New to me 2000 Vert, adjusted the top today so driver door doesn't rub top at corner, but also notice the top doesn't sit flush with the deck on the drivers side, but seems to on the passenger side. Is there an adjustment for this? Tried #5 bow adjustment, but that is for the more rear part of the top. See pics for better explanationAttachment 48197137
Attachment 48197138
Are you saying the driver side window was rubbing the fabric when open and close door? If so, might should look at window adjustments as well as top adjustment. I don't have a good link to post right now, but there are several adjustments on windows ... Forward or back in mounting cradle, Tip in or out, Front/ back angle and up down. Inside door panel and speakers need to to be removed to easily access these adjustments.
To Top Adjustable??
