Sticky Steering Wheel Hub Cover
I've noticed that my steering wheel center hub has become rather sticky, and seems like it can be easily scratched. I avoid touching it as a result. Is there a good cure for this? Anyone know the cause?
2001 convertible that sits a lot, often outside.
Needs to be cleaned.
This issue has come up numerous times. Here is a little reading material for you on the subject:
https://www.corvetteforum.com/forums...r-melting.html
https://www.corvetteforum.com/forums...ing-wheel.html
Have you used Armor All on it? When I bought mine, the dash, steering wheel and door panels were all sticky. The previous owner used Armour All. I cleaned it several times with vinyl cleaner and use only Aerospace 303. Now it stays dry and smooth. I used this to clean it before treating with 303:
Received 1,216 Likes
Once you remove all the sticky goo from the steering wheel center, then do use anything on it. I did the same removal process and now only use a mild soap to clean everything in the interior. When my vert does not have the protective cover on the top to protect from the sun, I have a dash pad and use a white towel to cover the steering wheel. It works great.
Moderator
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Common problem. I scrubbed mine and didn't put anything on it. After that it only required occasional cleaning.
If anyone mentions using goof off, DON'T.
Goof off is nothing but lacquer thinner, in a smaller container.
You should know what lacquer thinner does to any painted, or dyed surface.(it removes it), and in the case of vinyl, and plastic, it melts it.
Bob.
Bob.
