Shifter vibration
Old Aug 21, 2017 | 11:33 PM
Jax03z06's Avatar
Jax03z06
Default Shifter vibration
I've been having shifter vibration issues for alittle while now. I started to think it was the mgw shifter so I changed it back to stock and it's still vibrating. Has anyone came up with any fixes for this??
Old Aug 21, 2017 | 11:56 PM
grantv's Avatar
grantv
Did this start recently, or since you made a change of some sort?
Any chance it's just the LS6?
If no changes and new, maybe motor mount issue?
Old Aug 22, 2017 | 10:40 AM
Hotrodzz3's Avatar
Hotrodzz3
Have you checked the bushings on the the lower shifter housing? another thing to check is the **** itself, the insert sometimes comes loose inside the ****, I turned mine upside down and ran superglue down the splines and that stopped all rattling on mine.
Old Aug 22, 2017 | 11:17 AM
Jax03z06's Avatar
Jax03z06
This started happening after the clutch job. I did have a drivetrain vibration but that ended up being the aftermarket clutch. Before we narrowed down the clutch i changed the harmonic balancer and engine mounts. The drivetrain vibration is gone but there was still vibration in the shifter . I thought it was just the short throw shifter so I changed back to the stock shifter and it's still vibrating. Can you post a pic of the bushings your talking about?? I'd really appreciate it.
Old Aug 23, 2017 | 01:34 PM
Hotrodzz3's Avatar
Hotrodzz3
I got the bushings from zip products and here's the link
http://www.zip-corvette.com/97-16-sh...-bushings.html
and here's a picture of the bushings
and here they are installed in the lower housing.
Old Aug 23, 2017 | 07:37 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
with a MGW lower box you don't need any bushings other than what it comes with !!!!! MGW back to stock ????
Old Aug 24, 2017 | 12:34 AM
Hotrodzz3's Avatar
Hotrodzz3
Didn't realize he had changed the lower box out, my bad....
I'll go back to my corner now.
Old Aug 24, 2017 | 12:48 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
he could have the very early MGW that didn't come with the lower box ??? you can come out of the corner now !!!!
Old Aug 24, 2017 | 12:56 AM
Rexde1's Avatar
Rexde1
That's what I have and it rattles. I'm going to try the teflon tape trick for the ball.
Old Aug 24, 2017 | 01:00 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
the lower box is what sets the MGW apart from the rest, it is why they shift so well !!!! IMO !!!
Old Aug 24, 2017 | 04:16 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
It worked for me, and my MGW didn't come with a lower box.
To Shifter vibration
