DIY double din bezel mod
Old Aug 25, 2017 | 03:55 PM
Stroker87's Avatar
Stroker87
Default DIY double din bezel mod
hey guys! i been wanting to install a double din in my car since i already have installed amps, speakers & sub sent my bezel out to dennis he got backed up and was killing my nitrous install (switches mounted in cup holder) didnt want to have to rip the car apart more then once so he just sent it back to me being annoyed with time wasted (around a month) and winter coming up quick on us here in Illinois wanted to just get it done and over with so out came my tools!
after a bunch of checking, fitting and mounting i hacked up my bezel and got the radio in, ill be honest it dont look as nice the modded ones Dennis does, over the winder i'll send him a stock one i have around but all and all for zero spent in modding cost i think it looks "ok" better then some others i've seen hacked on but again not as nice as the double D stuff
if your on a budget this might be for you?
i cut (more like notched) bezel at the top of the radio and did the same for the bar that separates the radio and hvac control (didnt want to remove it) then use strips of plastic i had around painted them flat black and glued them on to fill the gaps on the sides of the radio
your thoughts? (honest options welcome)
Edit: i did not need to move the hvac control, only thing i had to do was remove the metal tray under the stock radio
Old Aug 25, 2017 | 04:35 PM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
I doubt anyone would notice the imperfection. Looks good.
I'd like to change to DD but my bezel is hydro dipped. I may be able to use a dremel without chipping the dip. Any thoughts?
Old Aug 25, 2017 | 04:52 PM
Stroker87's Avatar
Stroker87
thanks
score the finish with a sharp blade first then cut with a dremal slowly not to heat things up to much
i used masking tape at a guide for cutting
Old Aug 25, 2017 | 05:10 PM
OleStraightStick's Avatar
OleStraightStick
St. Jude Donor '08
I had to look closely to see it.. turned out perty nice!
Old Aug 25, 2017 | 05:47 PM
coia96vette's Avatar
coia96vette
Nicely done sir. May have to it a try on my '04.
Old Aug 25, 2017 | 07:11 PM
Mickeyrx70's Avatar
Mickeyrx70
Looks good to me ... and can't beat the price!
Old Aug 25, 2017 | 10:18 PM
Stroker87's Avatar
Stroker87
thanks
that was just test fitted not bolted in, once i get it fully installed ill take better pic with my camera those are just with my cell phone hopefully tomorrow!
Old Aug 26, 2017 | 10:58 AM
I think you did a really good job on the bezel.
Old Aug 26, 2017 | 08:12 PM
Stroker87's Avatar
Stroker87
better pics!
if i was to do this again a couple things i would do different, the vertical cuts i would use a just a hacksaw blade for a better cutting angle using my dremal i could not get a 90* angle and it shows with the right angle it was look better, the strip the separates the hvac and radio again if the angle was the same angle as the bottom of the radio it would look better
over all the final install looks decent but you can be the judge!
Old Aug 27, 2017 | 11:50 PM
striper's Avatar
striper
I am an owner of a Dennis modified bezel that I also covered in a very leather looking vinyl and others think looks very good, I think your mod looks pretty good. I think if you covered yours as I did mine, it would make it look even better and help to disguise where you cut it, to the point where you'd be able to consider it finished.
Old Aug 28, 2017 | 01:19 AM
Stroker87's Avatar
Stroker87
striper, thanks!
some point i might push my finishing skills idk?
To DIY double din bezel mod
