Horn doesn't work
Old Sep 12, 2017 | 07:42 PM
PaConehead's Avatar
PaConehead
Originally Posted by 8VETTE7
See above in RED.
I missed the link first time through - that helped! Horns are on the bench.
Old Sep 12, 2017 | 10:20 PM
dn69427's Avatar
dn69427
Originally Posted by Lexybird
how much was the repair in cost being you did it yourself
I think it was 60-70.00 on eBay, I already had the torx tools needed to do the job
Old Nov 30, 2024 | 03:12 PM
RoyalTermite's Avatar
RoyalTermite
5th Gear
Had similar problem. Relay and fuse were fine. Replaced membrane at the beginning of this year. Today, no horn and relay and fuse checked out. Held the steering f wheel adjustment lever and bounced the steering wheel up and down and bam, the horn now works. Probably a loose or dirty connection but quick fix till I have the time to take the horn assembly apart.
Hope this helps others.
Joe
Old Nov 30, 2024 | 10:46 PM
BRKLYN's Avatar
BRKLYN
You cannot take your se to a stealer. You sure it’s in the steering wheel? Mine been out for several years from a deep water travel, gonna get new horn just procrastinating. Chet underneath and disconnect factory horn and get an inexpensive horn from auto parts store and plug it and blow horn . I would do this first..😮1300-1400 hundred $$$. Excessive
