Temperature reading off?
Old Aug 30, 2017 | 10:08 AM
knewblewkorvette's Avatar
knewblewkorvette
Default Temperature reading off?
I just purchased a 99 6-speed. I noticed the outside temperature reading on the AC/heat controls is off. It reads about 25 degrees lower than the actual temperature outside the car. I'm thinking the temperature sensor is the culprit but I'm not sure. Could it be anything else?
Old Aug 30, 2017 | 10:23 AM
BRAVO1's Avatar
BRAVO1
VETERAN
I replaced the outside temp sensor and all was good......
Jim
Old Aug 30, 2017 | 04:23 PM
knewblewkorvette
I hope that's it, I just ordered a new GM one, $17 isn't bad at all.
Old Aug 30, 2017 | 04:26 PM
jcgunn's Avatar
jcgunn
Sometimes the connector just needs to be cleaned. They pick up a lot of road grime where the unit is mounted.
Old Aug 30, 2017 | 04:42 PM
Yes, I would say the temp sensor is bad. Replace it and I would bet your temp reading will be back to normal.
To Temperature reading off?
