[Z06] E85 Stabilizer
Old Sep 1, 2017 | 05:22 PM
z76232's Avatar
z76232
Default E85 Stabilizer
My Z06 has an LS7 tuned for and running E85. Does anyone here run E85 and are you using any kind of stabilizer additive to combat moisture?
Old Sep 3, 2017 | 01:44 AM
StingrayRebel's Avatar
StingrayRebel
get an ethanol content sensor plumbed into the return line with a gauge then test the fuel with a quick fuel tester before you put it in the tank... if the gauge ever reads a higher % content than what you know you put in then you have a moisture problem, if the gauge stays at or below what you tested not then don't worry about it in my opinion
Old Sep 3, 2017 | 11:42 AM
blackmachdown's Avatar
blackmachdown
I've been running e85 for years on my z06 and it sits over winter, i never really do anything no problems so far!
To E85 Stabilizer
