Grinding noise
Old Sep 2, 2017 | 04:15 PM
johnfin's Avatar
johnfin
Default Grinding noise
When ever I shut off my C5 with M6 it sound like noisy gears moaning, maybe like no oil in engine (which it has oil). Could it be the M6, throwout bearing, etc?
Old Sep 2, 2017 | 04:33 PM
ArtClassShank's Avatar
ArtClassShank
Shut it off with the clutch in. Report back. If the sound is gone, you have nothing to worry about.
Old Sep 2, 2017 | 05:24 PM
JR-01's Avatar
JR-01
Do you have a power antenna?
Old Sep 2, 2017 | 10:00 PM
johnfin's Avatar
johnfin
Default noise
I do have a power antenna but the noise is up front and the radio is off. I will check the clutch thing.
Old Sep 2, 2017 | 10:44 PM
JR-01's Avatar
JR-01
LOL. When I bought mine it had a horrible grinding sound when ever I shut it off. Took me a day or two to figure out it was the power antenna. Too bad for you, it was an easy fix.
Old Sep 2, 2017 | 11:32 PM
StingrayRebel's Avatar
StingrayRebel
, it's perfectly normal... just shut the car off with the clutch pressed in and you won't feel embarrassed
Old Sep 3, 2017 | 12:36 PM
El original's Avatar
El original
Its called the Corvette death rattle. Completely normal, just keep clutch disengaged when shutting down.
To Grinding noise
