Heater hose flush point
Old Sep 3, 2017 | 07:26 AM
mompantero's Avatar
mompantero
Default Heater hose flush point
I'm the "new" owner of a 1998 C5, never had a Corvette before. I'd like to install a Prestone Flush Kit but can't figure out where and which heater hose to plug it in. Does anyone have a picture or a description of where to install it? I think I know which are the heater hoses but I'm not sure and don't want to make any fatal mistakes! Would really appreciate the advice.
Old Sep 4, 2017 | 05:55 AM
foggy's Avatar
foggy
I wouldn't install one of those.. ever.
Just more points for failure.
You can "flush" your heater core by just removing one of the hoses
and using a garden hose.
Then take of lower hose at radiator and/or hose at waterpump.
If you want to do a flush for some reason (neglected system). I would
just drain as much as possible. Fill with clean water, Drive for a day or so.
Then repeat.
Old Sep 4, 2017 | 07:31 AM
mompantero's Avatar
mompantero
Then repeat.
Thanks, I'll do as you suggest. I'm not sure of the cars service history so I'm in the process of draining and replacing ALL fluids and filters.
Old Sep 4, 2017 | 09:14 AM
foggy's Avatar
foggy
That is a great idea !! Lots of people just drive...
You need to get to your base point. Then you'll know all about
it . Good Luck !
To Heater hose flush point
