Good morning all. Years ago when I first got my C5 it had T84 Euro headlight with the harness. The harnesses went bad and I replaces the bulbs with regular three prong H4's (9003). Has anyone used any led's in their T84's and if so how did they work and what bulb did you use? Thanks
Mostplus led bulbs are dependable and excellent improvement offer stock bulbs. I'd recommend to anyone.
MostPlus have excellent LED's...make sure you get the latest version of them as in 2017's. The early versions were not as good as the 2017's.
They had cooling ribbons, cooling fans, large starters/ballast and only had 180 degrees of light.
