Wheel and Tire question
Old Sep 5, 2017 | 01:40 PM
Robrote's Avatar
Robrote
Default Wheel and Tire question
As the summer slips away, I'll be purchasing a new set of 'shoes and socks' for Eliza, my 2000 baby. I'm unsure whether to keep the stock size wheels and tires or if I should increase the fronts or the rears (or both). There are so many conflicting opinions out there. My car is completely stock and I absolutely do not want to sacrifice any ride quality or have any rubbing issues.
Please let me know your thoughts.
Old Sep 5, 2017 | 02:30 PM
Robrote's Avatar
Robrote
Originally Posted by 8VETTE7
As an input to making that decision I suggest that you check out the availability of the STOCK tire sizes for the C5. You might be surprised to find out how few options on brands are available........
Tire size selection for 18" front and 19" rear wheels seems to be a bit better than that for the 17", 18" OEM combination......
Yes I have seen that. I'm not opposed to jumping up in size but I'm concerned with the drivability etc. I may be worrying for nothing.
Old Sep 5, 2017 | 02:32 PM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
If done properly, you won't have any issues whatsoever. Most of us who've done any modding at all - the first thing to upgrade is the footwear. There are about 8,433 threads here on wheel and tire upgrades. Start searching...
Old Sep 5, 2017 | 02:37 PM
JR-01's Avatar
JR-01
Keep stock sizes and you can't go wrong.
Old Sep 5, 2017 | 03:37 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
I run 18" and 19" with no issues at all. As c5vetteguy said, wheels and tires are one of the first changes many people make to their Vettes (as well as one of the first changes to Chevelles, Novas, Impalas, Mustangs, Hondas, Nissans, etc, etc).
The most important thing is do what is pleasing (and affordable) to you.
Old Sep 5, 2017 | 03:42 PM
Robrote's Avatar
Robrote
Did you go with the factory widths on the tires and just increase the diameter? Post a picture if it's convenient.
Old Sep 5, 2017 | 03:43 PM
Emerica88's Avatar
Emerica88
Wide 18s are becoming a thing of the past because the OEMs have all gone to 19s or 20s. Move up in size to help with your tire selection in the future.
Old Sep 5, 2017 | 04:32 PM
Tsumi's Avatar
Tsumi
The major players still have stock C5 sizes and will continue to do so in the foreseeable future. I wouldn't really worry about availability of choice.
Given that everything else is equal (same model tire, same tire diameter, etc), going to a taller wheel will result in reduced ride quality due to less sidewall.
Old Sep 5, 2017 | 04:44 PM
02BlownZ06's Avatar
02BlownZ06
This is a must read in my opinion: http://www.toquez06.com/wheels.html
Based on this I went with 19's all the way around and to the largest size recommended. No rubbing or computer issues since I kept the stagger the same.
Old Sep 5, 2017 | 05:13 PM
SG Lou's Avatar
SG Lou
I went from base C5 wheels with Continental tires to C6 wheels with Continental tires. No noticeable difference in ride quality or fitment / rubbing issues.
Old Sep 5, 2017 | 05:47 PM
Route99's Avatar
Route99
Here's a photo. Sorry, but not the best photographer; especially with an iPhone.
If I remember correctly, my wheels are 18x10 and 19x11 (don't remember offset, but wheel manufacturers and many on this site can assist you with this).
Hope this helps a little.
Old Sep 5, 2017 | 06:33 PM
nickb45502's Avatar
nickb45502
What are you looking to do? I have 2 C5 Z06 cars and a Z51 C6 vert. One of my Z06 is set up for autocross. I have 275 on the front and 315 on the rear.
Stay with stock sizes for best ride and balance. Going oversize will reduce the sidewall height, mess with the stability control, and ride like a rock. Plus mess with the neutral feel of the car.
Unless you race the car stay with stock sizes. IMHO.
Old Sep 5, 2017 | 06:34 PM
nickb45502's Avatar
nickb45502
This here.
Old Sep 5, 2017 | 06:43 PM
c5vetteguy's Avatar
c5vetteguy
...Given that everything else is equal (same model tire, same tire diameter, etc), going to a taller wheel will result in reduced ride quality due to less sidewall.
Moot point. I doubt the OP is necessarily considering the same tire and model as what he's currently running. They could be the original run flats for all we know. There are many aspects of a tire design that contribute to its overall performance, including ride quality. Things like materials used, construction processes, tread width and contact patch all help dictate a tire's ability to cushion. A shorter sidewall from one brand can be more compliant than a taller sidewall from another. I guarantee my larger diameter, larger width, smaller sidewall tires are more responsive, hence more comfortable, than the stock spec tires; especially when considering upgrading from run flats.
Old Sep 5, 2017 | 07:23 PM
Tsumi's Avatar
Tsumi
Yes, but if you're comparing a 275/40/18 Michelin PSS to a 275/35/19 Michelin PSS (same width, negligible difference in overall diameter), the 18 will have a better ride. How much better depends on the suspension setup and driver perception of what a better ride is. That's why I said all things being equal.
Old Sep 5, 2017 | 07:42 PM
deejbee's Avatar
deejbee
I have 18" on the front, 19" on the back. No rubbing. Drives fine.
Speedometer is off. Haven't really looked into it yet as it isn't that much of a bother to me at this point in time.
Old Sep 5, 2017 | 08:11 PM
c5vetteguy's Avatar
c5vetteguy
And that's why I said it's a moot point. I'm not disputing what you're saying, but why would you assume the OP would even consider the same model tire he's currently running, when there are plenty of alternatives available? Your statement is, for the most part, correct, but it has no real relevance to what the OP is asking.
To Wheel and Tire question
Old Sep 5, 2017 | 08:14 PM
Tsumi's Avatar
Tsumi
Because the subject of changing wheel diameters came up and the OP said he was willing to consider it...
Old Sep 5, 2017 | 08:52 PM
c5vetteguy's Avatar
c5vetteguy
How do you equate changing wheel diameter to keeping the same tire model? He didn't say he wants the same brand of tire, let alone the same model. Your statement stands true if he did say that, but he didn't.
Moot
Moot
Moot moot
Old Sep 5, 2017 | 08:57 PM
Tsumi's Avatar
Tsumi
Moot
Moot
Moot moot
How is it moot? Are you that obsessed with being right?
The main point is the OP is changing tires. The OP may also consider changing wheels. The OP mentioned ride quality as being important. I'm letting him know what the difference between for example 275/40/18 PSS on original wheels and 275/35/19 PSS on new 19" wheels would be. I didn't think I would need to spell this out for you. Is it that complicated to comprehend?
