[Z06] Axle or Boot Replacement?
Old Sep 7, 2017 | 06:28 AM
jumpmanmb87's Avatar
jumpmanmb87
Default Axle or Boot Replacement?
I have grease coming out of the lower CV boot on the axles, so its time to replace the axles or put new boots on. What's everyone doing these days because I searched through some dinosaur threads and would like some updated info.
Old Sep 19, 2017 | 12:31 PM
jumpmanmb87
Where's the best prices on GM axles? Any vendors on here? I'm tempted to try the remanufactured ones from cardone seeing its full warranty and half the price.
Old Sep 19, 2017 | 03:14 PM
jumpmanmb87
I do all my own work so I know nothing of repair shops. I've searched this forum for two days and its basically a 50/50 of aftermarket or GM with no real consensus. There is still no clear answer on what's the preferred method or what the majority does especially since this is a common problem. The inner boot has been discontinued and the outer will be in stock but who knows for how long. The car is 16years old and I would rather change the entire shaft then end up taking it out twice when the inner decides to go. If a vendor offered the shafts I would much rather purchase them instead of someone who doesn't support the forum.
To Axle or Boot Replacement?
