Help Diagnosing Sound
Old Sep 8, 2017 | 10:15 PM
Water_Walker's Avatar
Water_Walker
Default Help Diagnosing Sound
A&A Ti-trim stock ls6...
Motor starts and runs with constant slap sound. Blowby rolling out of dipstick tube if removed. Reving motor leads to backfires and popping. Power loss. Exhaust ironically looks normal.
I am guessing a ring let go.
What about anything else, like a lifter or valve issue?
Any good way to know without removing the motor? What about just removing the heads?
Old Sep 9, 2017 | 08:55 AM
JBB's Avatar
JBB
Pull the plugs & ck compression.(a leak down test would be better if you have the equipment) Pull the cover off the side with the dead hole. Find a friend with a borescope.
Honestly it doesn't sound promising.
Old Sep 9, 2017 | 11:36 AM
Rob 02's Avatar
Rob 02
Post results. The builder may have gotten a defective part or damaged a ring while putting a piston in.
It sucks but it happens.
To Help Diagnosing Sound
