? Battery tender
Old Sep 18, 2017 | 08:32 PM
C52002Vert's Avatar
C52002Vert
Default ? Battery tender
OK this might be a dumb question but, Can you unplug a tender from the car and leave it plugged in to the wall and not hurt the tender? I used the search and all I found was to leave it on the battery and not to worry but no mention of leaving it plugged in. My tender is mounted on the ceiling so I won't unplug it if I don't have to.
Old Sep 18, 2017 | 08:47 PM
Rob 02's Avatar
Rob 02
You can leave it plugged in but it will probably last a lot longer if you unplug it. It will still draw some power plugged in too.
Old Sep 18, 2017 | 09:34 PM
FX VETTE's Avatar
FX VETTE
Yes. Mine is always plugged into the wall regardless whether it is plugged into the car battery or not. I just make sure that the business end isn't touching anything when unused. You may hear some say that my house will burn down or the battery charger will have problems, but I haven't experienced any.
Old Sep 18, 2017 | 09:49 PM
When I disconnect my battery tended from the battery, I always unplug it from the wall also. Just a habit I got into as I don't see a need to have it plugged in when not connected to the battery.
Old Sep 18, 2017 | 11:08 PM
pjdbm's Avatar
pjdbm
I have the battery tender and it is also plugged into the ceiling, I leave it plugged in all the time, I disconnect the connection between battery clips and the unit so it does not come in contact with metal.
I know the sears battery tender states on the box that you must unplug the unit or risk burning it out, I know someone who had his Sears tender fail because of this.
Old Sep 18, 2017 | 11:19 PM
C52002Vert's Avatar
C52002Vert
Thanks for all the replies and the general thinking is that it "might" shorten the life of the tender or (burn down the house?), it also seems that it is possible that it will not do "anything". Again THANKS FOR THE REPLIES!
Old Sep 19, 2017 | 09:13 AM
MAC5's Avatar
MAC5
Use a 100 volt wireless remote switch in the ceiling receptacle.
Old Sep 19, 2017 | 09:58 AM
grantv's Avatar
grantv
My opinion... if you've gone to the trouble of ceiling hanging a charger, do a bit more work and create a way to unplug it. It's an active electrical device (creating electricity/heat), I wouldn't leave it plugged in without being hooked up.
Run a cord to a wall outlet, run a remote plug switch...
Your choice.
Old Sep 19, 2017 | 10:01 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
In four years I've never unplugged my tender.
Old Sep 19, 2017 | 11:02 AM
c4cruiser's Avatar
c4cruiser
I have a Battery Tender Junior plugged into a ceiling outlet above my C5 and I use the supplied end with ring terminals. The positive terminal is connected to the B+ post on the side of the fuse box and the ground terminal is connected to the ground post on the frame rail by the battery.
The Tender has been plugged in for over 5 years now ans still works fine. I usually connect the Tender to the car if I won't be driving it for a week or more. I don't think there is any problem with leaving this brand of maintainer plugged in to 120v power when not in use.
Old Sep 19, 2017 | 11:19 AM
ArmchairArchitect's Avatar
ArmchairArchitect
Banned Scam/Spammer
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
I've had my Battery Tender Jr plugged into the wall for several years now, no issues. Just make sure the ends/clamps are in a safe place without risk of touching metal or each other.
Old Sep 19, 2017 | 12:15 PM
oh1vette's Avatar
oh1vette
I'm old school - still unplug my toaster.....
Old Sep 19, 2017 | 12:41 PM
pjdbm's Avatar
pjdbm
If you think about it....
I also have a better tender on my house generator, I start that about 5 times a year, the rest of the time it is plugged in.
These are made to be plugged in 24/7 and when they fail, you buy a new one.
I learned the hard way with the generator and had to buy a new batter at $75.00 6 months or so after I replaced it.
Old Sep 19, 2017 | 11:05 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
You're always going to draw some current if it is plugged in whether it's charging the battery or not. You might want to feel the body of the charger after it's "idled" for some time to make sure it's not hot. If so, you should definitely unplug it between uses.
Old Sep 20, 2017 | 08:36 AM
strand rider's Avatar
strand rider
I don't think it a problem, but it is an open circuit , and should be considered as such, at least by me, so I would unplug, or de-energize the circuit.
I didn't think about any riskalong those lines until I was getting some electrical help over the phone. He mentioned the possible risk to the car , how he would never leave a battery tender hooked up to the car.
I apply the same thinking to the wall circuit. The risk is very low, but the loss could be high. Anything without a switch, I unplug, in case of fire. I think it also is a recommended policy, cutting parasitic loss nationwide reduces consumption.
To ? Battery tender
