[Z06] Valve Spring TDC Method Question
Old Sep 24, 2017 | 02:40 PM
Anthony F's Avatar
Anthony F
Veteran: Marine Corps
Default Valve Spring TDC Method Question
I'm currently replacing the yellow valve springs with new blues in my 2003. I'm using the TDC method while using a straw in the spark plug hole and watching the valve springs. My question is how precise does the piston have to be at TDC, if i'm off a few degrees will it be a problem or is in the ballpark good enough?
Old Sep 24, 2017 | 02:54 PM
MY03C5Z's Avatar
MY03C5Z
I used the compression method when I did mine, much simpler imo. If you already have the plugs out, I don't see why you wouldn't just do it that way. Once you attach the airfitting and the hose there's no question the cylinder is ready to go. Just saying.
Old Sep 24, 2017 | 02:57 PM
Anthony F's Avatar
Anthony F
I have everything out and ready to go and brought #6 up very close to TDC. I don't want to buy a compressor and biggest reason of all, i don't like the idea of losing pressure and then dropping a valve.
Old Sep 24, 2017 | 03:17 PM
MY03C5Z's Avatar
MY03C5Z
Oh I can see if you don't have a compressor that method makes more sense. I did the tdc method on my LT1 z28 before but it's been a while, never did it on an LS engine.
Old Sep 24, 2017 | 06:25 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
I kind of did the same with the exception of, I inserted a nylon string, about 3/16 dia, into the plug hole, turned the crank with a socket wrench until it wouldn't pull out. When tougt the piston was near top dead and the string filled any gap between the piston and the valves. Make sure you have enough slack sticking out. I think the string was about 2 feet long, not all was fed in, maybe 9 inches and this process makes it pretty mindless and no worry of valve dropping or compresser failure. Tryed the compresser way but didn't like all the hissing and really wanted to take my time, being it was the first.
Old Sep 24, 2017 | 08:06 PM
bumble-z's Avatar
bumble-z
I agree w/Punz...No fear, no problems method.
Old Sep 24, 2017 | 08:23 PM
Anthony F's Avatar
Anthony F
Sounds great, thanks.
Old Sep 28, 2017 | 06:08 PM
Anthony F's Avatar
Anthony F
Took much longer then i expected but it's done! No cracks or any visible problems with the yellows.
Old Sep 29, 2017 | 09:16 AM
MY03C5Z's Avatar
MY03C5Z
Looking good, it's the best insurance you can get for the ls6
Old Sep 29, 2017 | 02:10 PM
socal_Dad's Avatar
socal_Dad
Great job! I used the rope on a few cylinders and did a few without. How about you?
I found that once I got a feel for getting the keepers popped back in, I was OK at TDC without the rope.
Old Sep 30, 2017 | 01:42 AM
Anthony F's Avatar
Anthony F
I thought about it halfway through but just kept on with the rope.
Old Oct 3, 2017 | 10:17 AM
punz's Avatar
punz
Glad it worked out for you guys, not to bad to do. I think the screw, front drivers side, that held the coil bracket was the toughest part.
Old Oct 4, 2017 | 03:50 PM
socal_Dad's Avatar
socal_Dad
Funny you mentioned that! You can see in this picture that I backed out the alt mount bolt to get access to that one and I put some blue masking tape on that bolt so I would remember to tighten it back down.
Old Oct 9, 2017 | 03:48 PM
punz's Avatar
punz
A little more info
Rope method is safe way and for tightening rockers, pic is from manual. To find #1 at TDC of compression use a straw or dowel rod and watch the intake valve, then put chalk mark on balancer for the second rotation. Once you do that your set.
Old Oct 9, 2017 | 10:04 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
To clarify, my 01z had blue .525 lift springs from the factory. The modern blue are different of course, but this is a tidbit I wanted to share.
If you own an 01z and aren't the original owner, don't think your blues are the new style.
To Valve Spring TDC Method Question
